1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: no device support in ACRScr motor
To: l123173 <[email protected]>, tech-talk <[email protected]>
Date: Mon, 12 Mar 2018 11:04:20 +0000
Hi Li Xing,
All of the model 3 drivers use the same device support.  It is in motorApp/MotorSrc/devMotorAsyn.c.
There are several examples of motor.substitutions files in motor/iocBoot/iocWithAsyn.  This is motor.substitutions.xps5.  Note that it uses DTYP "asynMotor" and the addressing information is PORT and ADDR.
file "$(TOP)/db/basic_asyn_motor.db"
pattern
{P,    N,   M,         DTYP,     PORT, ADDR, DESC,      EGU,     DIR,   VELO,  VBAS, ACCL, BDST, BVEL, BACC,    MRES, PREC,   DHLM,   DLLM, INIT}
{IOC:, 1, "m$(N)", "asynMotor",  XPS1,  0, "Phi",      degrees,  Neg,    4.0,   0.1,  .25,    0,    1,   .2,    .001,     3,    180,   -180, ""}
{IOC:, 2, "m$(N)", "asynMotor",  XPS1,  1, "Kappa",    degrees,  Neg,    6.0,   0.1,  .88,    0,    1,   .2,    .0001,    4,    180,   -180, ""}
{IOC:, 3, "m$(N)", "asynMotor",  XPS1,  2, "Omega",    degrees,  Neg,    7.0,   0.1,  1.5,    0,    1,   .2,    .0001,    4,    360,   -180, ""}
{IOC:, 4, "m$(N)", "asynMotor",  XPS1,  3, "Psi",      degrees,  Neg,    4.0,   0.1,   .5,    0,    1,   .2,    .00025,   4,    190,   -190, ""}
{IOC:, 5, "m$(N)", "asynMotor",  XPS1,  4, "2theta",   degrees,  Neg,    4.0,   0.1,  1.0,    0,    1,   .2,    .0001,    4,    196,    -17, ""}
{IOC:, 6, "m$(N)", "asynMotor",  XPS1,  5, "Nu",       degrees,  Neg,    4.0,   0.1,   .5,    0,    1,   .2,    .00025,   4,    190,   -190, ""}
{IOC:, 7, "m$(N)", "asynMotor",  XPS1,  6, "Dummy1",   degrees,  Neg,    4.0,   0.1,   .5,    0,    1,   .2,    .00025,   4,    190,   -190, ""}
{IOC:, 8, "m$(N)", "asynMotor",  XPS1,  7, "Dummy2",   degrees,  Neg,    4.0,   0.1,   .5,    0,    1,   .2,    .00025,   4,    190,   -190, ""}
From: [email protected] <[email protected]> on behalf of l123173 <[email protected]>
Sent: Monday, March 12, 2018 4:18 AM
To: tech-talk
Subject: no device support in ACRScr motor
Hi all ,
    I have a question about device support.
    I checked the motor module, the ACRSrc was different from others, such as PiSrc.
    PiSrc has device support, but ACRSrc not, only  ACRMotorDriver.cpp and ACRMotorDriver.h.
    Even if ACRSrc was version 3 mode, it should still have the device support, I wonder where is the device support.
    Could someone help me, please.
Li xing
no device support in ACRScr motor l123173
Prev: RE: Mako G-234B (6408) - Prosilica Area Detector question tom.cobb
Next: Re: Recipe for creating a new record Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: no device support in ACRScr motor l123173
Next: problem building 3.15.5 Maren Purves
ANJ, 13 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
