1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EtherCAT newbie question
Date: Mon, 12 Mar 2018 18:10:31 +0000
I think anyone considering the Beckhoff EL terminals should look into the EK9000. As Scott Stubbs has already mentioned, we're working on the driver. Using the EtherCAT master is overkill if you don't need realtime control.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Friday, March 9, 2018 10:00 AM
To: [email protected]
Subject: Tech-talk Digest, Vol 12, Issue 131
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. RE: EtherCAT newbie question ([email protected])
   2. Mako G-234B (6408) - Prosilica Area Detector question
      (Mark Engbretson)
   3. problem using motor record and SNL (Hovanes Egiyan)
   4. RE: problem using motor record and SNL (Mark Rivers)
Message: 1
Date: Fri, 9 Mar 2018 10:44:45 +0000
To: <[email protected]>, <[email protected]>
Message-ID: <8EFA35F526EF5844AC9901A91B73BBBB0104E3BFBE@exchmbx01>
Content-Type: text/plain; charset="iso-8859-1"
Mark,
There are series of Beckhoff EtherCAT modules in different physical formats, which do similar functions.  Ronaldo has listed module numbers we would deploy on a beamline.
 https://www.beckhoff.com/english/ethercat/ethercat_terminals.htm?id=235616333
We deploy them together in chains of EtherCAT nodes, each needs a coupler module.
However Beckhoff also produce a format called EtherCAT Box, which we have used at DLS in smaller numbers.
https://www.beckhoff.com/english/fieldbus_box/news_ethercat_box.htm?id=23562552546
Depending what you want to do with your system, but if you literally want a minimal lab system to play with some EtherCAT software, you might be better off selecting from this series because each EtherCAT box unit is its own coupler, constituting an EtherCAT node in its own right,  so no extra coupler unit is required.  The wiring connectors are different.
Also there is a series of digital combi units, which we would not deploy but which can do input and output and would reduce the minimum number of modules to buy still further to 3 (excluding your motion requirement)
https://www.beckhoff.com/english/fieldbus_box/digcombi.htm?id=197298967461991
Linda
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: 07 February 2018 09:36
To: [email protected]; [email protected]; [email protected]
Hi Mark,
As Torsten and Jeong Han have already said, the Diamond Ethercat EPICS support is available [1], but it does not support motion.
For some digital I/O and analog I/O we would use kit from our supported set [2].
The master in our setup runs on a Dell R310, using Redhat MRG (real time pre-empt rt kernel).
The minimal ethercat kit would be:  EK1100 coupler, EL1014 (digital input), EL3104 (analogue input), EL2024 (digital output), EL4134 (analogue output).
Best regards,
Ronaldo
[1] https://github.com/dls-controls/ethercat
[2] See https://epics.anl.gov/tech-talk/2015/msg01665.php
From: [email protected] [mailto:[email protected]] On Behalf Of Torsten B?gershausen
Sent: 07 February 2018 05:29
To: Mark Rivers; [email protected]
Subject: Re: EtherCAT newbie question
Hej Mark,
this is what we use for our motion control test/development crates:
# CPU: CX5130
# Configure EL1018 digital input terminal # Configure EL2808 digital output terminal # Configure EL5101 incremental encoder terminal, motor 1 # Configure EL5101 incremental encoder terminal, motor 2 # Configure EL9505 Power supply terminal 5V # Configure EL1252 digital input terminal # Configure EL7037 stepper drive terminal, motor 1 # Configure EL7037 stepper drive terminal, motor 2
(No analog IO in our motion crates ;-)
No sure if you have access to this page about other terminals for motion:
https://confluence.esss.lu.se/display/MCAG/Motion+Controller
HTH
/Torsten
PS:
As Han Lee pointed out, there are different SW packages:
- Beckhoff TwinCAT
- Linux ("scanner" from DLS and ecat2 from PSI) (but no motion control)
- Linux ECMC from ESS http://icalepcs2017.vrws.de/talks/mocpl05_talk.pdf
And we are happy to help.
On 06/02/18 20:37, Mark Rivers wrote:
> I am interested in trying out EtherCAT with a simple inexpensive
> setup.? What are the minimum parts I need to buy if I want to use the
> EPICS EtherCAT driver to control some digital I/O, analog I/O, and a
> stepper motor?? I looked at the Beckhoff website, but I find it overwhelming.
> Thanks,
> Mark
Message: 2
Date: Fri, 9 Mar 2018 09:36:33 -0600
To: <[email protected]>,    "'Mark Rivers'"
        <[email protected]>
Subject: Mako G-234B (6408) - Prosilica Area Detector question
Message-ID: <[email protected]>
Content-Type: text/plain; charset="us-ascii"
Mark,
I recently deployed  a GigE camera Mako G-234B from Allied Vision with the
Prosilica Area Detector but noticed a bit of oddness with the expected frame
rate. The camera data sheet lists 41.2 FPS as the readout rate,10-bit sensor
readout but the Xml file from the camera shows feature(s) of
<Feature Name="AcquisitionFrameRateAbs" Type="Float"
Access="R/W">31.872511</Feature>
<Feature Name="PixelFormat" Type="Enumeration" Access="R/W">Mono8</Feature>
<Feature Name="SensorReadoutMode" Type="Enumeration"
Access="R/W">Readout12Bits</Feature>
Which is the frame rate which Area Detector seems to acquiring at.
I am assuming that I would have to implement "SensorReadoutMode" to be able
to get the expected FPS, or am I missing an existing parameter that might
already do this?
Me
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20180309/c80b03d5/attachment.html>
Message: 3
Date: Fri, 9 Mar 2018 11:35:50 -0500
Cc: Vanik Kakoyan <[email protected]>
Subject: problem using motor record and SNL
Content-Type: text/plain; charset=utf-8; format=flowed
we are trying to move a motor and then stop it using EPICS sequencer
code and motor record.
The state code dials the desired location into the VAL field via pvPut()
and makes
the motor move. If the user requests the motion to be aborted during the
motion, the
state code attempts to stop the motor either using STOP field or SPMG
fields. And for some reason this does not work. Actual change of the
SPMG field to
"Stop" only happens when the motor motion is complete, and setting
STOP field to 1 from the state code does not have any effect.
But if either moving the motor is done using caput to the VAL field or
the stopping the motor is done via caput to the STOP or SPMG fields, it
works. What is
the reason for such a behavior? Is this expected? Any advice would be
appreciated.
We are using motorR6-8 and seq-2.1.12 for this with R3-14-12-3 on RHEL6.
 ??? Hovanes Egiyan.
Message: 4
Date: Fri, 9 Mar 2018 17:23:45 +0000
To: 'Hovanes Egiyan' <[email protected]>,
Subject: RE: problem using motor record and SNL
Content-Type: text/plain; charset="utf-8"
The problem must be that your SNL code is effectively doing a ca_put_callback when it writes to the VAL field.  That will wait for the motor to complete the move.  Are you using the "SYNC" option on pvPut()?  If so you should remove it.
> Of Hovanes Egiyan
> Sent: Friday, March 09, 2018 10:36 AM
> Hi,
> and makes
> motion, the
> SPMG field to
> works. What is
> appreciated.
> Thanks,
>  ??? Hovanes Egiyan.
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 12, Issue 131
Prev: Re: Recipe for creating a new record Ralph Lange
Next: Re: StreamDevice with Telnet port Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EtherCAT newbie question Linda.Pratt
Next: Tech-talk search fields throw errors Southern, Tim
ANJ, 13 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
