His record is processing at 10Hz so it takes effect in 100 ms without FLNK.
Sent from my iPhone
On Mar 15, 2018, at 10:31 AM, Southern, Tim <[email protected]<mailto:[email protected]>> wrote:
SMOO does not update record when it changes, correct? Wouldn't you need to add a FLINK in the ao record to make this work?
record(ao, "$(dev):sm") {
field(DESC, "Smoothing")
field(OUT, "$(dev):rawval.SMOO")
field(FLNK, "$(dev):rawval")
- Tim
Field SMOO is not a link field. You need to arrange for the sm record to write its value to rawvalue.SMOO. To do that you need to change it from an ai to an ao record.
This should work:
From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of Amien Crombie
Sent: Thursday, March 15, 2018 6:18 AM
To: EPICS Tech-Talk <[email protected]<mailto:[email protected]>>
Subject: SMOO expects constant
Hi here I have 2 of my database records:
1) record(ai, "$(dev):sm") {
2) field(DESC, "Smoothing")
3) }
4) record(ai, "$(dev):rawval") {
5) field(SCAN, ".1 second")
6) field(DTYP, "asynInt32") #
7) field(INP, "@asyn(int32 $(addr) 100)")
8) field(SMOO, "$(dev):sm")
9) field(FLNK, "$(dev):coef")
This fails on
Can't set "bc1:rawval.SMOO" to "bc1:sm"
Error at or before ")" in file "db/newioc8.db" line 8
If I put a constant (0 - 1) in line(8) it works
Amien
- SMOO expects constant Amien Crombie
- RE: SMOO expects constant Mark Rivers
- Re: SMOO expects constant Southern, Tim
Asyn - max addresses per port Amien Crombie
<2018>
2025
2026
Motor Record not moving distances less than .5 Sobhani, Bayan
<2018>
2025
2026
