1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SMOO expects constant
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 15 Mar 2018 15:31:10 +0000
SMOO does not update record when it changes, correct? Wouldn’t you need to add a FLINK in the ao record to make this work?
record(ao,            "$(dev):sm")    {
      field(DESC,        "Smoothing")
      field(OUT,         "$(dev):rawval.SMOO")
      field(FLNK,       "$(dev):rawval")
- Tim
Field SMOO is not a link field.  You need to arrange for the sm record to write its value to rawvalue.SMOO.  To do that you need to change it from an ai to an ao record.
This should work:
From: [email protected] [mailto:[email protected]] On Behalf Of Amien Crombie
Sent: Thursday, March 15, 2018 6:18 AM
Subject: SMOO expects constant
Hi here I have 2 of my database records:
1)    record(ai,            "$(dev):sm")    {
2)       field(DESC,        "Smoothing")
3)    }
4)    record(ai,            "$(dev):rawval")        {
5)        field(SCAN,        ".1 second")
6)        field(DTYP,        "asynInt32")          #
7)        field(INP,         "@asyn(int32 $(addr) 100)")
8)        field(SMOO,        "$(dev):sm")
9)        field(FLNK,        "$(dev):coef")
This fails on
Can't set "bc1:rawval.SMOO" to "bc1:sm"
Error at or before ")" in file "db/newioc8.db" line 8
If I put a constant (0 - 1) in line(8) it works
Amien
Re: SMOO expects constant Mark Rivers
SMOO expects constant Amien Crombie
RE: SMOO expects constant Mark Rivers
Prev: RE: Motor Record not moving distances less than .5 Sobhani, Bayan
Next: Re: SMOO expects constant Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: SMOO expects constant Mark Rivers
ANJ, 15 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
