If you have maxAddress=N there is nowhere that you tell asynManager the value of N. It allocates storage for device M when it is first referenced. So you could have a single address of 10000 and that does not use any more memory than having a single address of 1.
However, asynPortDriver does require you to specify the value of N because it create N parameter table arrays in the constructor. In the future asynPortDriver could be changed to use an std::map to map address to parameter table and then it could also allocate on-demand.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Eric Norum
> Sent: Thursday, March 15, 2018 11:27 AM
> To: Amien Crombie <[email protected]>
> Cc: EPICS Tech-Talk <[email protected]>
> Subject: Re: Asyn - max addresses per port
> There is nothing in ASYN that would prohibit this. I have drivers with dozens of addresses
> on a single ASYN port.
> > On Mar 15, 2018, at 9:19 AM, Amien Crombie <[email protected]> wrote:
> > Hi
> > I have a 8-channel Asyn driver that allows me to have 1 port with 8 addresses. Each
> address holds a int32.
> > Now I want to go to 48 addresses...is it possible?
> > I'm using asyn-4-21
> > Amien
> Eric Norum
> [email protected]
- Re: Asyn - max addresses per port Amien Crombie
- Asyn - max addresses per port Amien Crombie
- Re: Asyn - max addresses per port Eric Norum
<2018>
2025
2026
<2018>
2025
2026
