Thanks Mark/Eric
Appreciate the quick response
On 2018/03/15 18:33, Mark Rivers wrote:
If you have maxAddress=N there is nowhere that you tell asynManager the value of N. It allocates storage for device M when it is first referenced. So you could have a single address of 10000 and that does not use any more memory than having a single address of 1.
However, asynPortDriver does require you to specify the value of N because it create N parameter table arrays in the constructor. In the future asynPortDriver could be changed to use an std::map to map address to parameter table and then it could also allocate on-demand.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf
Of Eric Norum
Sent: Thursday, March 15, 2018 11:27 AM
To: Amien Crombie <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Subject: Re: Asyn - max addresses per port
There is nothing in ASYN that would prohibit this. I have drivers with dozens of addresses
on a single ASYN port.
On Mar 15, 2018, at 9:19 AM, Amien Crombie <[email protected]> wrote:
Hi
I have a 8-channel Asyn driver that allows me to have 1 port with 8 addresses. Each
address holds a int32.
Now I want to go to 48 addresses...is it possible?
I'm using asyn-4-21
Amien
Eric Norum
[email protected]
- Asyn - max addresses per port Amien Crombie
- Re: Asyn - max addresses per port Eric Norum
- RE: Asyn - max addresses per port Mark Rivers
Re: Motor Record not moving distances less than .5 Kevin Peterson
<2018>
2025
2026
<2018>
2025
2026
