Thanks everybody for the fast answers-
I think I was looking for "2slit_soft.vdb, which uses soft motor records,
instead of ao records, for center and width."
The good news: I got it working!
There is one question about the collision avoidance:
If the Gap is 0 and the slit is closed, and I move the center
there seems to be the risk for a collision, or better said,
that one blade is slightly started earlier and "pusshing" the other
one. I am not sure if this is a real-life problem.
The other thing is that I need to check the calculation of the
soft limits for the virtual motors.
The most obvious is that the rule "Gap > 0" is not there.
(And the other calculations need to be checked)
I'll set up a system with a simulator.
And of course, we are setting up a system as well,
where the synchronization is done in the motor controller.
On 08/03/18 18:20, Mooney, Tim M. wrote:
There is also, in the optics module, 2slit_soft.vdb, which uses soft motor
records, instead of ao records, for center and width.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
*From:* [email protected] <[email protected]> on behalf
of Goetze, Kurt A. <[email protected]>
*Sent:* Thursday, March 8, 2018 10:51:13 AM
*To:* Torsten Bögershausen; [email protected]
*Subject:* RE: Controling a slit system with 2 hard and 4 soft motorrs
Hi Torsten,
The synApps optics module has support for this type of thing:
https://github.com/epics-modules/optics/blob/master/opticsApp/Db/2slit.db
Kurt
-----Original Message-----
From: [email protected] [mailto:[email protected]] On
Behalf Of Torsten Bögershausen
Sent: Thursday, March 08, 2018 10:40 AM
To: [email protected]
Subject: Controling a slit system with 2 hard and 4 soft motorrs
Hej motorists,
I recently learned about the transform record, which can be used to control a
slit with 2 physical axes in the way that you can set the values for GAP and
CENTER and the position of the physical blades are calculated. (Or vice versa)
Does anybody have a super-duper-luxus template file which uses 4 soft motors
together with some calc and transform records ?
Thanks in advance
/Torsten
- Re: Controling a slit system with 2 hard and 4 soft motorrs Mark Rivers
- Re: Controling a slit system with 2 hard and 4 soft motorrs Pearson, Matthew R.
- Controling a slit system with 2 hard and 4 soft motorrs Torsten Bögershausen
- RE: Controling a slit system with 2 hard and 4 soft motorrs Goetze, Kurt A.
- Re: Controling a slit system with 2 hard and 4 soft motorrs Mooney, Tim M.
RE: Motor Record not moving distances less than .5 Sobhani, Bayan
<2018>
2025
2026
<2018>
2025
2026
