Hi Andrew
Yes, I made mistake it must be $(chan) and not INDX.
I'm using Base R3.14.12.3 running on a BeagleBone Black (os Ubuntu 14.04
LTS) and please explain the easier way on Base 3.15 or >
Thanks
Amien
On 2018/03/16 17:31, Andrew Johnson wrote:
Hi Amien,
On 03/16/2018 09:19 AM, Amien Crombie wrote:
I have a subarray record that looks like this:
record(subArray, "$(dev):$(channame)") {
field(SCAN, ".1 second")
field(FTVL, "FLOAT")
field(DTYP, "Soft Channel")
field(INP, "$(dev):xcur") ## INP comes from a waveform of 8 floats
field(NELM, "1")
field(MALM, "8")
field(INDX, "$(chan)") ## chan macro starts at 0
field(FLNK, "$(dev):mychan$(INDX)")
What are you trying to achieve with the above FLNK value? Did you mean
to use $(chan) instead of $(INDX)? Do you have 8 copies of this record,
one each for chan=1, chan=2 etc?
record(ai, "$(dev):mychann$(chan)") {
This is possibly not the right way to do it. Is there a better way?
I suspect you may be trying to extract each of the individual values
from the waveform into their own ai record, is that correct?
Which version of EPICS Base are you using? There is an easier way than
creating 8 subArray records if you are using a 3.15 or later release of
Base.
- Andrew
- Re: SubArray to ai record Andrew Johnson
- SubArray to ai record Amien Crombie
Re: StreamDevice with Telnet port Mark Rivers
Re: StreamDevice with Telnet port Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
