1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SubArray to ai record
To: Amien Crombie <[email protected]>
Cc: [email protected]
Date: Fri, 16 Mar 2018 10:31:41 -0500
Hi Amien,
On 03/16/2018 09:19 AM, Amien Crombie wrote:
> I have a subarray record that looks like this:
> record(subArray,  "$(dev):$(channame)") {
>      field(SCAN,  ".1 second")
>      field(FTVL,  "FLOAT")
>      field(DTYP,  "Soft Channel")
>      field(INP,   "$(dev):xcur")  ## INP comes from a waveform of 8 floats
>      field(NELM,  "1")
>      field(MALM,  "8")
>      field(INDX,  "$(chan)")   ## chan macro starts at 0
>      field(FLNK,  "$(dev):mychan$(INDX)")
What are you trying to achieve with the above FLNK value? Did you mean
to use $(chan) instead of $(INDX)? Do you have 8 copies of this record,
one each for chan=1, chan=2 etc?
> record(ai,        "$(dev):mychann$(chan)")        {
> This is possibly not the right way to do it. Is there a better way?
I suspect you may be trying to extract each of the individual values
from the waveform into their own ai record, is that correct?
Which version of EPICS Base are you using? There is an easier way than
creating 8 subArray records if you are using a 3.15 or later release of
Base.
- Andrew
Re: SubArray to ai record Amien Crombie
Prev: SubArray to ai record Amien Crombie
Next: RE: StreamDevice with Telnet port Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: SubArray to ai record Amien Crombie
ANJ, 22 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
