1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SubArray to ai record
To: EPICS tech-talk <[email protected]>
Date: Thu, 22 Mar 2018 13:19:20 +0200
Hi Andrew
Thanks for that info on new array filters in Base 3.15 and higher.
I just have to compile my Beaglebone with the new Base and it should work.
Regards
Amien
On 2018/03/16 17:31, Andrew Johnson wrote:
Hi Amien,
On 03/16/2018 09:19 AM, Amien Crombie wrote:
I have a subarray record that looks like this:
record(subArray,  "$(dev):$(channame)") {
      field(SCAN,  ".1 second")
      field(FTVL,  "FLOAT")
      field(DTYP,  "Soft Channel")
      field(INP,   "$(dev):xcur")  ## INP comes from a waveform of 8 floats
      field(NELM,  "1")
      field(MALM,  "8")
      field(INDX,  "$(chan)")   ## chan macro starts at 0
      field(FLNK,  "$(dev):mychan$(INDX)")
What are you trying to achieve with the above FLNK value? Did you mean
to use $(chan) instead of $(INDX)? Do you have 8 copies of this record,
one each for chan=1, chan=2 etc?
record(ai,        "$(dev):mychann$(chan)")        {
This is possibly not the right way to do it. Is there a better way?
I suspect you may be trying to extract each of the individual values
from the waveform into their own ai record, is that correct?
Which version of EPICS Base are you using? There is an easier way than
creating 8 subArray records if you are using a 3.15 or later release of
Base.
- Andrew
SubArray to ai record Amien Crombie
Re: SubArray to ai record Andrew Johnson
Prev: How to start EPICS IOC via LabVIEW on cRIO 赵泽锋
Next: seq error 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SubArray to ai record Andrew Johnson
Next: Asyn getting DTYP field in drvUserCreate() Konrad, Martin
ANJ, 22 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
