1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: seq error
To: tech-talk <[email protected]>
Date: Thu, 22 Mar 2018 23:14:11 +0800 (GMT+08:00)
Hi all,
     When I make the seq in my ioc, I met some questions. I use synapps5_8, seq-2-2-1, fedora27(64), base 3.14.15.
     I setup sncNewRT.stt file and did the following step as the manual of seq said:
"Assume you have a SNL program file named *test.st* then the steps to
build are, in principle::
   snc test.st
   cc -c test.c -o test.o ...additional compiler options...
   cc test.o -o test ...additional linker options...
or, if SNL sources are to be pre-processed::
   cc -E -x c test.st > test.i
   snc test.i
   cc test.o -o test ...additional linker options..."
I did it as "not pre-processed" way, typed "snc sncNewRT.stt ", "cc -c sncNewRT.c -o sncNewRT.o ", then "cc sncNewRT.o -o sncNewRT".
When I typed the last command( cc sncNewRT.o -o sncNewRT ), I got the following error:
[lyx@localhost src]$ cc sncNewRT.o -o sncNewRT
/usr/lib/gcc/x86_64-redhat-linux/7/../../../../lib64/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
sncNewRT.o: In function `seqg_event_tem_change_0_init':
sncNewRT.c:(.text+0x37): undefined reference to `seq_delay'
sncNewRT.o: In function `seqg_action_tem_change_0_cool':
sncNewRT.c:(.text+0x141): undefined reference to `seq_pvPutTmo'
sncNewRT.o: In function `seqg_action_tem_change_0_heat':
sncNewRT.c:(.text+0x1e1): undefined reference to `seq_pvPutTmo'
sncNewRT.o: In function `sncNewRTRegistrar':
sncNewRT.c:(.text+0x1ed): undefined reference to `seqRegisterSequencerCommands'
sncNewRT.c:(.text+0x1f7): undefined reference to `seqRegisterSequencerProgram'
collect2: error: ld returned 1 exit status
My sncNewRT.dbd:
registrar(sncNewRTRegistrar)
My sncNewRT.stt:
program sncNewRT
float tem_indoor;
int run_cool_heat;
int run_auto;
int tem_up;
int tem_low;
assign tem_indoor to "{user}:Tem_indoor";
assign run_cool_heat to "{user}:Air_Run";
assign tem_up to "{user}:Tem_Up";
assign tem_low to "{user}:Tem_Low";
assign run_auto to "{user}:Run_Auto";
monitor run_auto;
monitor tem_indoor;
monitor tem_up;
monitor tem_low;
ss tem_change {
    state init {
        when (delay(3)) {
            printf("sncNewRT start\n");
            if (run_auto == 0)
                printf("run_auto = 0\n");
            else
                printf("run_auto != 0\n");
        } state cool
    state cool {
        when (tem_indoor > tem_up) {
            printf("begin to cool\n");
                run_cool_heat = 1;
                pvPut(run_cool_heat);
        } state heat
    state heat {
        when (tem_indoor < tem_low) {
            printf("begin to heat\n");
                run_cool_heat = 2;
        } state cool
My makefile in App/src:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
LIBRARY_IOC += Longin
DBD += Longin.dbd
Longin_SRCS += devLongin.c
Longin_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = NewRT
# NewRT.dbd will be created and installed
DBD += NewRT.dbd
# NewRT.dbd will be made up from these files:
NewRT_DBD += base.dbd
# Include dbd files from all support applications:
NewRT_DBD += Longin.dbd
# Add all the support libraries needed by this IOC
#NewRT_LIBS += xxx
# NewRT_registerRecordDeviceDriver.cpp derives from NewRT.dbd
NewRT_SRCS += NewRT_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
NewRT_SRCS_DEFAULT += NewRTMain.cpp
NewRT_SRCS_vxWorks += -nil-
NewRT_LIBS += Longin   # add the line
# To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
    # Build sncExample into exampleSupport
    sncNewRT_SNCFLAGS += +r
    NewRT_DBD += sncNewRT.dbd
    # A .stt sequence program is *not* pre-processed:
    NewRTSupport_SRCS += sncNewRT.stt
    NewRTSupport_LIBS += seq pv
    NewRT_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    # A .st sequence program *is* pre-processed:
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Finally link to the EPICS Base libraries
NewRT_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
Could you give me some suggestion.
Liang yx
Re: seq error Ralph Lange
Prev: Re: SubArray to ai record Amien Crombie
Next: Re: seq error Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How to start EPICS IOC via LabVIEW on cRIO Baily, Scott A
ANJ, 26 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
