1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Pushing values to device on (re)connection to IOC
To: [email protected]
Date: Fri, 23 Mar 2018 23:29:46 +0100
Hi Andrew,
I could spend a small portion of my life to help this. However, you and community should be OK with my bad English first :) If it is OK, please guide me how to do this.
Hi Eric,
While I am reading your email, I remembered my old question again, and I actually am writing similar DB file recently.
I would like to sync a PV value of Set with a PV value of RB in the case when an IOC should be restarted with the assumption that the device is ON. I asked Michael (MD), his codes help to figure out how to do this long ago.
It only covers 50% of your case. I hope it may help you more to make your ioc robustly. Here is db snip codes
``` ----- snip -----
record(bo, "$(P)Update-Cmd")
	field(PINI, "YES")
	field(ZNAM, "Revert")
	field(ONAM, "revert")
	field(FLNK, "$(P)Update:Fout_")
record(fanout, "$(P)Update:Fout_")
	field(LNK1, "$(P)PLL-RB")
record(bo, "$(P)PLL-Sel")
	field( OUT, "@a.proto setVal(LO,i) $(PORT)")
	field(ZNAM, "Open")
	field(ONAM, "Closed")
	field(FLNK, "$(P)PLL-RB")
record(bi, "$(P)PLL-RB")
	field( INP, "@a.proto getVal(LO,i) $(PORT)")
	field(ZNAM, "Open")
	field(FLNK, "$(P)PLL-RB_")
record(longout, "$(P)PLL-RB_")
	field( DOL, "$(P)PLL-RB NPP")
	field(OMSL, "closed_loop")
	field( OUT, "$(P)PLL-Sel NPP")
``` --- snip snip -----
   Thank you.
   Best,
   Han
On 03/23/2018 08:57 PM, Andrew Johnson wrote:
On 03/23/2018 02:28 PM, Eric Norum wrote:
Is there a 3.15 version of the record reference manual somewhere?  The
one I’ve been using
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14
is clearly old.
No, using a wiki didn't work well with multiple parallel releases, and
updating all those tables is almost impossible, so we started converting
those pages into Perl POD format inside the record.dbd file.
We strip off the POD before installing the DBD files, and generate HTML
from the POD and DBD info as part of the Build process (so the tables
get updated automatically). Unfortunately as you'll see if you look in
your base-3.15/html directory though we haven't got terribly far with
the conversion process. Help with this is always welcome, email me!
My quick attempt at trying the above with the 4 changed to a 5 didn’t
result in much useful….
Check the release notes for a description of the record-type changes:
     https://epics.anl.gov/base/R3-15/5-docs/RELEASE_NOTES.html
- Andrew
Pushing values to device on (re)connection to IOC Eric Norum
Re: Pushing values to device on (re)connection to IOC Andrew Johnson
Re: Pushing values to device on (re)connection to IOC Eric Norum
Prev: CSDataQuick 1.0 Release Wang Xiaoqiang (PSI)
Next: EPICS Collaboration Meeting, June 11-15 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Pushing values to device on (re)connection to IOC Andrew Johnson
Next: CSDataQuick 1.0 Release Wang Xiaoqiang (PSI)
ANJ, 23 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
