1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How Pilatus (ADPilatus) IOC process image
Date: Thu, 29 Mar 2018 15:46:52 -0300
Hi Mark,
Thank you again,
one last question:
On 29-03-2018 15:44, Mark Rivers wrote:
Hi Gabriel,
On Mar 29, 2018, at 1:30 PM, Gabriel de Souza Fedel <[email protected]> wrote:
Hi Mark,
thank you for the answer.
On 29-03-2018 15:23, Mark Rivers wrote:
Hi Gabriel,
The Pilatus IOC receives an image from camserver that is already corrected for bad pixels and flat field.
Ok! And Can I set the flat field file (used on camserver) with pilatus ioc?
No, the flat file that camserver uses is based on factory measurements at specific energies and thresholds. When you select the energy and threshold in the IOC camserver constructs a flat field file by interpolating the factory measured ones.
The IOC can do additional bad pixel and flatfield corrections if enabled. This feature may be deprecated and moved to the plugin layer in the future.
This adition bad pixel and flatfield correction cames from the IOC PVs (flat field file, ...)?
Yes, that is correct.
Great!
And this addition correction is applied to result image, right?
Gabriel
Sent from my iPhone
On Mar 29, 2018, at 1:19 PM, Gabriel de Souza Fedel <[email protected]> wrote:
Hello,
Can someone explain if pilatus IOC modify the image generated by pilatus?
I would like to know how the flat field correction (from pilatus ioc) works. I think pilatus ioc doesn't use camserver flat field correction, that's right?
Thank you!
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
Re: How Pilatus (ADPilatus) IOC process image Mark Rivers
How Pilatus (ADPilatus) IOC process image Gabriel de Souza Fedel
Re: How Pilatus (ADPilatus) IOC process image Gabriel de Souza Fedel
Prev: Re: How Pilatus (ADPilatus) IOC process image Mark Rivers
Next: Re: How Pilatus (ADPilatus) IOC process image Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
