1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question about pvAccess monitor
To: renato sanhueza <[email protected]>
Date: Mon, 2 Apr 2018 17:57:27 +0000
> On Apr 2, 2018, at 12:28 PM, renato sanhueza <[email protected]> wrote:
> Maybe I didn’t express myself correctly, but I was asking for the scenario in which the client doesn´t know a priori the details about the server that it wants to monitor (e.g. it might be a thermometer, a power supply, a fan, an antenna, etc).
Hi Renato—
Knowing only the name of the variable, the client can request the structure. For example, using the command-line pvget utility . . .
$ pvget BL6:Det:Metadata
BL6:Det:Metadata
structure
    time_t timeStamp 2018-04-02T13:32:08.794 19815342
    epics:nt/NTScalar:1.0 proton_charge
        double value 0
    epics:nt/NTScalarArray:1.0 time_of_flight
        uint[] value []
    epics:nt/NTScalarArray:1.0 pixel
        uint[] value []
 . . . tells me that the variable BL6:Det:Metadata has a structure consisting of a timeStamp, a NTScalar value for proton_charge, and NTScalarArrays for time_of_flight and pixel.
The client can then decide it wants to monitor only the timeStamp . . .
$ pvget -m BL6:Det:Metadata -r timeStamp
BL6:Det:Metadata
structure
    time_t timeStamp 2018-04-02T13:38:55.189 19839726
BL6:Det:Metadata
structure
    time_t timeStamp 2018-04-02T13:38:55.206 19839727
BL6:Det:Metadata
structure
    time_t timeStamp 2018-04-02T13:38:55.223 19839728
> So the question is:
> Can a client use metadata to understand a message from an unknown server? (known as dynamic communication)
> Or the software developer has to known the structure of the server to make the client (static communication)
If you are using Normative Types, the client will understand the structure of the data. (In the example above, the structure is application specific, but the structure is built from standard normative types.)
However, using your example, for the client to understand that a structure is intended to represent a fan and that the speed is the variable to control, would likely require additional information on the client side.
Steven Hartman
[email protected]
Re: question about pvAccess monitor Kasemir, Kay
question about pvAccess monitor renato sanhueza
Re: question about pvAccess monitor Johnson, Andrew N.
Re: question about pvAccess monitor Mark Rivers
Re: question about pvAccess monitor renato sanhueza
Re: question about pvAccess monitor Marty Kraimer
Prev: Re: question about pvAccess monitor Marty Kraimer
Next: Re: question about pvAccess monitor Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 02 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
