1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: motor card not exist
To: tech-talk <[email protected]>
Date: Tue, 3 Apr 2018 17:39:10 +0800 (CST)
Hi all,
       I used the motor module, epics 3.14.12.5 to control the motor.
       But could not connect the card of motor.
      i could ping the ip(192.168.1.120), and nmap the port(12321), it was open.
      The PC and motor controller connect with a router.  The pc has two network card, used the enp2s0 to the router for the website. enp3s0 was used for detector, and I pulled out the cable since the motor could not success.
      Does I have something wrong?
Part ofThe output of st.cmd.
 Motors
#dbLoadTemplate("basic_motor.substitutions")
dbLoadTemplate("motor.substitutions")
drvAsynIPPortConfigure("L0","192.168.1.120:12321")
# motorUtil (allstop & alldone)
dbLoadRecords("/home/ygz/synApps_5_8/support/motor-6-9/db/motorUtil.db", "P=xxx:")
ARIESSetup(2,20)
ARIESConfig(2,"L0",1)
#var drvARIESdebug 4
iocInit
Starting iocInit
## EPICS R3.14.12.7
## EPICS Base built Mar 27 2018
Illegal field value PV: xxx:m1 motor_init_record_com(): card does not exist!
Illegal field value PV: xxx:m2 motor_init_record_com(): card does not exist!
Illegal field value PV: xxx:m3 motor_init_record_com(): card does not exist!
Illegal field value PV: xxx:m4 motor_init_record_com(): card does not exist!
Output of dbior :
epics> dbior drvARIES
Driver: drvARIES
    ARIES controller 0 connection failed.
    ARIES controller 1 connection failed.
[root@localhost iocLinux]# ifconfig
enp2s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:0b:ab:d6:a5:0b  txqueuelen 1000  (Ethernet)
        RX packets 15429  bytes 1798058 (1.7 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
enp3s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.106  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::20b:abff:fed6:a50c  prefixlen 64  scopeid 0x20<link>
        ether 00:0b:ab:d6:a5:0c  txqueuelen 1000  (Ethernet)
        RX packets 5482216  bytes 1571278998 (1.4 GiB)
        TX packets 6514277  bytes 1410616920 (1.3 GiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 6107773  bytes 2433948286 (2.2 GiB)
        TX packets 6107773  bytes 2433948286 (2.2 GiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.122.1  netmask 255.255.255.0  broadcast 192.168.122.255
        ether 52:54:00:12:e3:90  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
li xing
Re: motor card not exist Mark Rivers
Prev: Re: question about pvAccess monitor Marty Kraimer
Next: Re: motor card not exist Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Simple channel access write program within Qt Abdalla Ahmad
ANJ, 08 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
