1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Simple channel access write program within Qt
To: "Kasemir, Kay" <[email protected]>
Date: Sun, 8 Apr 2018 05:36:38 +0000
Thank you Kay, that explains a lot.
Abdalla.
Sent: Tuesday, April 03, 2018 4:08 PM
To: Abdalla Ahmad <[email protected]>
Subject: Re: Simple channel access write program within Qt
Hi:
I assume you have multiple threads.
Some 'main' thread that starts everything up,
the UI thread that handles button presses etc. from the UI,
and then another worker thread in which you write, since you wouldn't want to delay the UI with such work.
-->  See the section on using CA from multiple threads in the CA manual, https://epics.anl.gov/base/R3-14/8-docs/CAref.html#Client2
-Kay
From: [email protected] <[email protected]> on behalf of Abdalla Ahmad <[email protected]>
Sent: Tuesday, April 03, 2018 3:36 AM
To: [email protected]
Subject: Simple channel access write program within Qt
Hi
As part of experimenting with EPICS Qt with EPICS Base 3.14.12.3, I came to the need to write a function that writes values to PVs. Here is my attempt:
int status;
chid id;
CA_SYNC_GID gid;
ca_search(name, &id);
status = ca_pend_io(1); // Already checking if status != ECA_NORMAL
ca_put(type, id, &value); // type can be DBF_STRING, DBF_DOUBLE, etc.
This is already working fine but I have some questions:
1.       I used to have ca_task_initialize and ca_task_exit but my Qt application always crashes on executing the function, the value is written but the app crashes. I thought since CA is already initialized and cleaned-up within EPICS Qt I removed both functions and the app works fine. Is this a correct behavior?
2.       When do I really need the synchronous group version of ca_put(the ca_sg_put)?
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo
Simple channel access write program within Qt Abdalla Ahmad
Prev: Re: question about pvAccess monitor renato sanhueza
Next: Problem with autosave module making it crash at random basis. Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Simple channel access write program within Qt Abdalla Ahmad
Next: motor card not exist l123173
ANJ, 08 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
