The pvaPy does implement introspection of data structures, but it doesn’t look like it does in C++ so Marty probably didn’t recognize it. The documentation for pvaPy covers that topic, and the result is more Pythonic.
- Andrew
Sent from my iPad
On 04/02/2018 04:29 PM, renato sanhueza wrote:
Thanks for all your answers, you solved my doubt. As Steven and Key noted, the client needs additional information to be able to interpret the remote interface. Fortunately this is not the responsibility of the middleware (i.e. EPICS).
EPICS can implement dynamic communication for monitoring as mentioned by Marty:
For pvAccess the client can get the introspection interface for the pvStructure associated with a channel.
It is obtained via a call to getField()
It can do this only after it has connected to the channel.
If an empty string is specified for subField then what the client receives is the introspection interface
for the top level PVStructure for the channel.
The client can then use this introspection interface to compose a request string for creating a channelGet, ..., monitor.
My final questions regarding this topic are:
1. Can I use this introspection interface with C++, Java and Python?
In C++ and Java yes.
In pvaPy I took a quick look and did not see code that implements it.
I will guess that it would not be hard to add but I will leave this for someone else to answer.
2. Can I use this introspection interface to retrieve the name of a service and its parameter list to compose a RPC during runtime by following Marty's approach?
I suspect that the answer for pvAccess itself is no.
But even if the answer is no a channelRPC service can implement it's own query service that describes itself.
But it must describe itself via pvData.
Marty
For example, In a program that I made I used static RPC by hardcoding the name of the service and matching the parameters required (a PVStructure) during development time,
RPCClientImpl client = new RPCClientImpl("control");
client.request(pvTelescopeParameters, REQUEST_TIMEOUT);
I understand that using static communication is more straightforward and easy for the developers and will probably be used the 90% of the time. So my question is more theoretical:
Can a client discover the service name ( control) and the parameters required to compose the RPC during runtime (dynamic RPC)?
Thanks again for the help, Now I will check the example sent by Mark,
Best regards,
Renato
- question about pvAccess monitor renato sanhueza
- Re: question about pvAccess monitor Johnson, Andrew N.
- Re: question about pvAccess monitor Mark Rivers
- Re: question about pvAccess monitor renato sanhueza
- Re: question about pvAccess monitor Marty Kraimer
- Re: question about pvAccess monitor Hartman, Steven M.
- Re: question about pvAccess monitor Kasemir, Kay
About EPICS7 Shen, Guobao
Re: About EPICS7 Torsten Bögershausen
<2018>
2025
2026
RE: question about pvAccess monitor [email protected]
<2018>
2025
2026
ANJ, 05 Apr 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
