Hi
We are using the Gamma QPC for the storage ring and the beamlines. The control is simply done using Stream Device. It works fine but you might get a timeout every
couple of hours. Seems like there is a problem with the controller itself. We are controlling it through Ethernet so you might want to try the serial port or ModBus.
Attached is the protocol file we are using for voltage and pressure readings and the channel enable/disable functions. Setpoints and relays control was not required,
it is done through the Agilent XGS600 gauge controller.
Dear Martin,
As I mentioned, we are facing a timeout issue with these controllers, are you facing a similar issue with your solution?
Best Regards,
Abdalla.
One of our staff has been working on QPC support. I am not sure what functionality he has reached beyond monitoring. I have included him on this message.
Phil Sorensen
On 04/10/2018 06:01 AM, Jack wrote:
Does anyone use Gamma Vacuum QPC 4 vacuum pump controller ?
Thank you
Mauro Giacchini
![https://img.newoldstamp.com/f/000/049/u818.png]()
Control System Specialist ISTITUTO
NAZIONALE DI FISICA NUCLEARE
p/f: 0039.049.80.68.558 a: Viale
universita' 2, 35020 Legnaro, PD -ITALY-
![Avast logo]()
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
www.avast.com
