1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS CAS errors
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 10 Apr 2018 13:16:54 -0500
Ralph,
thank you for your suggestions. I agree, such problems are very hard to debug, they are intermittent and most likely caused by memory corruption.
According to my observations these errors happen at start time of a beamline control application which establish connections/monitors to large number of EPICS PVs.
I don't think these errors caused by access rights changes, since our beamline control applications does not change any access rights.
Oleg
On 4/10/2018 4:44 AM, Ralph Lange wrote:
Hi Oleg,
Remote diagnosis of an unknown system is always more of a guessing game than anything else.
So, first and most important suggestion: refer to a local expert.
Nevertheless, some thoughts:
Statistically, many if not most weird errors on the IOC are caused by memory corruption.
In your case, the thread suspensions happen when the CA server on the IOC calls db_event_enable (line 477) or db_event_disable (line 493), and trying to acquire the monitor lock fails with an error.
The routines db_event_enable / db_event_disable are called from within the CA server when access rights change for a record or when a client sets up / cancels a monitor.
Were there access rights changes happening on the IOC at 07-Apr 19:59:10 and 08-Apr 08:11:10 (at the "line 493" events)?
Some "line 477" thread suspensions happen with intervals of a few minutes. That could match a client repeatedly getting ungracefully disconnected (because of the server-side thread being suspended) and then reconnecting, provoking another attempt to lock an invalid monitor lock and get disconnected again.
The semaphore locking code is used everywhere, all the time, all over EPICS Base. Not an obvious candidate for a bug.
So ... I think what you see may be consistent with a memory corruption that affects at least one record (i.e. the pointer to its monitor lock semaphore) or the memory area where the semaphore structures have been allocated.
Too bad that the error messages don't show the record involved. That would give valuable information.
Memory corruption issues (if there is one) are not easy to track down; strategies and tools depend on the operating system. Which closes the loop to my first and most important suggestion: refer to a local expert.
Cheers,
~Ralph
On Mon, Apr 9, 2018 at 10:40 PM, Oleg A. Makarov <[email protected]> wrote:
Ralph,
could you please provide some suggestions how to diagnose what causing suspension of CAS-client threads ?
Thank you,
Oleg
EPICS CAS errors Oleg A. Makarov
Re: EPICS CAS errors Ralph Lange
Re: EPICS CAS errors Oleg A. Makarov
Prev: Re: driver support for Gamma Vacuum QPC 4 Phillip Sorensen
Next: RE: driver support for Gamma Vacuum QPC 4 Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS CAS errors Martin L. Smith
Next: Re: EPICS CAS errors Dirk Zimoch
ANJ, 24 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
