1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: sscan question
To: tech-talk <[email protected]>
Date: Thu, 12 Apr 2018 21:44:52 +0800 (CST)
Hi all,
      I am using the synapps_5_8, centos 7(64) ,base 3.14.12.
      I want to use sscan module control two motors and one detector(xspress).
      The xspress worked with its own IOC. Motor was controlled with motor module in another IOC. Both the two IOC were in one PC.
      I got these error after I configured the sscan(Driver and trigger) and started it.
epics> Starting new scan with unexpected faze ('SCAN_PENDING')."
In the scan_more.opi, xxx:m1.SMSG was read and shows "Waiting for PV's to conect."
      Besides the error above, I have some questions.
      1. Does the trigger and drive in sscan could be in two different IOC of one PC?  Beacuse the xspress(using epics) was provided by manufacture, so I try to keep it originally?
      2. About the detector(xspress), the output of detector was a hdf5 file, so I could not know what the pv( xxx:scan1.D01PV ) should be.
      3. If I would change the savefile name during the sscan, how should I do it.
      4. I think sscan 2D would be right for me, but I could not know the value of macro Q. When I set it to m1, it was confilct with motor macro, When I set it to Table1X, it was not right also.
Li xing
RE: sscan question Mark Rivers
Re: sscan question Matt Newville
Prev: Re: Which record is the best to use? Mooney, Tim M.
Next: RE: sscan question Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Which record is the best to use? Ralph Lange
ANJ, 13 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
