1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Which record is the best to use?
To: "Ivashkevych, Oksana" <[email protected]>, Tech-talk <[email protected]>
Date: Wed, 11 Apr 2018 14:40:52 +0000
One way to implement a loop is which a calcout record.  The CALC _expression_ determines whether or not to loop, and the OOPT field specifies the condition in which the output link is executed.  The output link should a CA link, otherwise EPICS will break what looks to it like an infinite loop.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Ivashkevych, Oksana <[email protected]>
Sent: Wednesday, April 11, 2018 8:21:46 AM
To: Tech-talk
Subject: Which record is the best to use?
Hello,
I would like to automate phasing of servomotors in Delta Tau.
1.      Send phasing command via asyn, wait
2.      If Phasing successful(bit x is set), ->DONE
3.      If Phasing error(bit y is set),  do 1 again.
I would like to do it in the database, and not via sequencer, because it will give me a luxury of using a substitution file and repeating the same for 9 motors and looks much easier. It would be interesting to see how Delta Tau will handle several simultaneous phasing requests.
Thank you for your advice.
Oksana
Re: Which record is the best to use? Maren Purves
Which record is the best to use? Ivashkevych, Oksana
Prev: Re: Which record is the best to use? Pearson, Matthew R.
Next: sscan question l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Which record is the best to use? Maren Purves
ANJ, 12 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
