1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Possible deadlock issue with asyn layer?
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 16 Apr 2018 11:32:57 -0400
We have been experiencing a deadlock problem with one of our custom drivers based on the asynPortDriver class, and after reviewing the code and information gained via the gdb debugger, I have a theory regarding the cause that I would like others to review and tell me if there are any flaws they can spot (either in my logic or my assumptions).
First, a summary of the driver that is exhibiting the problem:
   - Non-blocking driver based on asynPortDriver class
   - One device per driver instance
   - Communication with device handled by a thread launched by each instance of the driver
   - All asyn calls by driver thread surrounded by lock()/unlock() calls
   - info(asyn:READBACK, "1") tag used in some of the output records
   - writeXxx() calls don't do any I/O:  They save the new value to be processed later        (and sometimes call setXxxParam(), setParamStatus(), and callParamCallbacks() functions)
   The driver thread runs periodically to update readings and process new settings as follows:
      - reads values form the controller
      - calls lock()
      - calls setXxxParam() and setParamStatus() as needed
      - calls callParamCallbacks() to update the records affected by the changes (acquiring the scan lock for each record while it is processed)
      - calls unlock()
      - Send new settings to the controller (using lock()/unlock() when calling any asyn functions or driver values that are touched by the writeXxx() functions)
   Concurrently with the driver threads usual processing, writes to output records occur.    The processing of each write (I assume) includes the following sequence of events:       - The thread that did the write (a CAC-client thread, in this case) gets the scan lock for the record and begins processing the record       - Processing of the record includes calls to asyn layer functions, which requires acquiring the asyn lock for the driver instance before calling one of its writeXxx() functions
      - The asyn lock for the driver is released
      - The scan lock for the record is released
What is happening:
   The driver thread sometimes blocks indefinitely waiting to acquire the scan lock for an output record it needs to update
My theory as to what can cause this:
   What we know:
      - The driver thread blocks indefinitely waiting for the scan lock for an output record that includes the info(asyn:READBACK, "1") tag
        (see extract from gdb output below and the template for the record)
      - The lockup of the driver thread is always preceded by a CA client write to an output record for one of the driver's parameters          (haven't yet confirmed it is the same record that the driver is waiting for when it hangs)
   What I believe is happening:
      - Sometime after the driver calls lock() and when it blocks waiting for the scan lock for an output record, a CA client thread writes to the same record.  It successfully acquires the scan lock for the record, but then blocks waiting to acquire the asyn lock for the driver instance (which the driver thread already has).
Obviously, if I am correct, the easiest way to avoid the problem is to eliminate the use of the info(asyn:READBACK, "1") tag (at least for any case where this could happen).  We don't actually need those tags for this database anymore, so that is something we will be trying shortly.
But can anyone point out a mistake in my reasoning or my assumptions?  IS this something we need to be aware of when using the info tag?
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
========================== from gdb ===================================
#0  __lll_lock_wait () at ../nptl/sysdeps/unix/sysv/linux/x86_64/lowlevellock.S:135
#1  0x00007f294a554494 in _L_lock_952 () from /lib/x86_64-linux-gnu/libpthread.so.0
#2  0x00007f294a5542f6 in __GI___pthread_mutex_lock (mutex=0x18db030) at ../nptl/pthread_mutex_lock.c:114
#3  0x00007f294adc17a3 in mutexLock (id=0x18db030) at ../../../src/libCom/osi/os/posix/osdMutex.c:46
#4  0x00007f294adc197f in epicsMutexOsdLock (pmutex=0x18db030)
    at ../../../src/libCom/osi/os/posix/osdMutex.c:130
#5  0x00007f294adb85fb in epicsMutexLock (pmutexNode=0x18db070)
    at ../../../src/libCom/osi/epicsMutex.cpp:143
#6  0x00007f294b019733 in dbScanLock (precord=0xe9d7d0) at ../../../src/ioc/db/dbLock.c:265
#7  0x00007f294bf8e18d in interruptCallbackOutput (drvPvt=0x1d08640, pasynUser=0x1d08f98, value=0)
    at ../../asyn/devEpics/devAsynUInt32Digital.c:500
#8  0x00007f294bf74540 in paramList::uint32Callback (this=0xb3cd50, command=358, addr=0,     interruptMask=4294967295) at ../../asyn/asynPortDriver/asynPortDriver.cpp:628
#9  0x00007f294bf74adc in paramList::callCallbacks (this=0xb3cd50, addr=0)
    at ../../asyn/asynPortDriver/asynPortDriver.cpp:750
#10 0x00007f294bf76417 in asynPortDriver::callParamCallbacks (this=0xb3ce60, list=0, addr=0)
    at ../../asyn/asynPortDriver/asynPortDriver.cpp:1510
#11 0x00007f294bf763a7 in asynPortDriver::callParamCallbacks (this=0xb3ce60)
    at ../../asyn/asynPortDriver/asynPortDriver.cpp:1496
_________________________________________________________________________________
Jump to any frame in the callstack to examine arguments (frame 6, here):
(gdb) f 6
265     ../../../src/ioc/db/dbLock.c: No such file or directory.
(gdb) p precord
$1 = (dbCommon *) 0xe9d7d0
(gdb) p *(dbCommon *)precord
$2 = {name = "MPS_FPS:MSTR_N0001:Slave11_MaskBit42-Sel", '\000' <repeats 20 times>,   desc = '\000' <repeats 40 times>, asg = '\000' <repeats 28 times>, scan = 0, pini = 0, phas = 0, <snipped>
record(bo, "$(SYS)_$(SUB):$(DEV)_$(INST):Slave$(SLAVE)_MaskBit$(BIT)-Sel")
  field(DTYP, "asynUInt32Digital")
  field(OUT,  "@asynMask($(ASYN_PORT),0,$(ASYN_MASK),$(TIMEOUT)) slave$(SLAVE)Mask$(MASK_REG)_Set")
  field(ZNAM,"Mask")
  field(ONAM,"Unmask")
  info(autosaveFields, "VAL")
Re: Possible deadlock issue with asyn layer? Pearson, Matthew R.
RE: Possible deadlock issue with asyn layer? Mark Rivers
Prev: Re: EPICS 7 Compilation in windows-64 Vishnu Patel
Next: Re: Possible deadlock issue with asyn layer? Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 16 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
