Hi Jörn,
looking at your dbLoadRecords it seems you are about four times over
the default MAX ARRAY bytes (16 kB); 8000 x float64 (8 bytes) = 64kB.
Try lowering the count NELEMENTS=1000 and see if that works.. if all
good you can set an environment variable to handle more than 16 kB by
exporting EPICS_CA_MAX_ARRAY_BYTES in BOTH, IOC and command line where
caget is executed:
# in IOC
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 10000000
# in terminal setting to 10Mb
export EPICS_CA_MAX_ARRAY_BYTES=10000000
HTH, hinko
On Tue, Apr 17, 2018 at 2:24 PM, Jörn Dreyer <[email protected]> wrote:
> I'm currently developing an areaDetector module for a sensor that delivers its
> information as double values. The code is ready, but I'm somehow not able to
> setup the ioc correctly to deliver the data in the NDStdArray. Looking with
> caget at the ArrayData it shows all values as zero.
> Here is what my dbLoadRecords line looks like:
> dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$
> (PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$
> (PORT),TYPE=Float64,FTVL=FLOAT,NELEMENTS=8000")
> My question is, has anybody before tried to read floats? With another driver
> that reads UInt32 values, I succeeded to setup the ioc.
> Regards,
> Jörn Dreyer
.. the more I see the less I believe.., AE AoR
- Re: areaDetector question Jörn Dreyer
- areaDetector question Jörn Dreyer
Re: PV gateway renders PVs as disconnected Ralph Lange
<2018>
2025
2026
<2018>
2025
2026
