1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector question
To: [email protected]
Date: Tue, 17 Apr 2018 15:18:25 +0200
Hi Hinko,
I tried your suggestion, but still no success. That's what ca get delivers
back.
~ $caget -d 2 HIBEF:XFEL:image1:ArrayData | more
    Native data type: DBF_FLOAT
    Request type:     DBR_FLOAT
    Element count:    1000
    Value:            2.02038e-39 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
I looked at the array in the readout function of the driver,. There it is
correctly filled with meaningfull values.
Jörn
Am Dienstag, 17. April 2018, 14:58:43 CEST schrieb Hinko Kocevar:
> Hi Jörn,
> looking at your dbLoadRecords it seems you are about four times over
> the default MAX ARRAY bytes (16 kB); 8000 x float64 (8 bytes) = 64kB.
> Try lowering the count NELEMENTS=1000 and see if that works.. if all
> good you can set an environment variable to handle more than 16 kB by
> exporting EPICS_CA_MAX_ARRAY_BYTES in BOTH, IOC and command line where
> caget is executed:
> # in IOC
> epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 10000000
> # in terminal setting to 10Mb
> export EPICS_CA_MAX_ARRAY_BYTES=10000000
> HTH, hinko
> On Tue, Apr 17, 2018 at 2:24 PM, Jörn Dreyer <[email protected]> wrote:
> > I'm currently developing an areaDetector module for a sensor that delivers
> > its information as double values. The code is ready, but I'm somehow not
> > able to setup the ioc correctly to deliver the data in the NDStdArray.
> > Looking with caget at the ArrayData it shows all values as zero.
> > Here is what my dbLoadRecords line looks like:
> > dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$
> > (PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$
> > (PORT),TYPE=Float64,FTVL=FLOAT,NELEMENTS=8000")
> > My question is, has anybody before tried to read floats? With another
> > driver that reads UInt32 values, I succeeded to setup the ioc.
> > Regards,
> > Jörn Dreyer
Dr. Joern Dreyer
HIBEF DAQ + Controls
Institut für Strahlenphysik
Helmholtz-Zentrum Dresden - Rossendorf e.V
Abt. FWKX                Tel: +49 351 260 3263
                                   FAX: +49 351 260 3700
01314 Dresden        eMail: [email protected]
Helmholtz-Zentrum Dresden - Rossendorf e.V (HZDR)
Bautzner Landstraße 400, 01328 Dresden
Vorstand: Prof. Dr. Dr. h. c. Roland Sauerbrey, Dr. Ulrich Breuer
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Re: areaDetector question Hinko Kocevar
areaDetector question Jörn Dreyer
Prev: Re: PV gateway renders PVs as disconnected Ralph Lange
Next: Re: areaDetector question Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: areaDetector question Hinko Kocevar
ANJ, 17 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
