Hi
From GCC 5( not exact version I know), the following FLAGS is needed to
compile the ADPointGrey without changing codes :
# https://gcc.gnu.org/wiki/FAQ#Wnarrowing
# https://gcc.gnu.org/bugzilla/show_bug.cgi?id=55783
# -std=c++11
USR_CXXFLAGS += -Wno-narrowing
HTH,
Han
On 04/21/2018 12:29 AM, Mark Rivers wrote:
Hi Kaz,
I build ADPointGrey on linux-x86_64 with no problems. I am using gcc 4.8.5. I think the issue is that you are using gcc 6.3.0. It looks like a minor modification is needed for newer gcc. You can figure out what is needed and make a pull request.
From: [email protected] <[email protected]> on behalf of Gofron, Kazimierz <[email protected]>
Sent: Friday, April 20, 2018 4:55 PM
To: [email protected]
Subject: ADPointGrey with AD3-2, and base-7.0.1.1
I am compiling ADPointGrey and running into code error in "pointGrey.cpp:245" . Did anyone compiled ADPointGrey recently on linux- 64bit ?
Best regards,
Kaz
base-7.0.1.1
AreaDetector 3-2
debian 9
gmaile 4.1
gcc 6.3.0
kaz@xf10id-is1:/epics/synApps/support/areaDetector-3-2/ADPointGrey$ make
make -C ./configure install
make[1]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/configure'
perl -CSD /epics/base-7-0-1-1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/configure/O.linux-x86_64'
perl -CSD /epics/base-7-0-1-1/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/configure/O.linux-x86_64'
make[1]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/configure'
make -C ./pointGreySupport install
make[1]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreySupport'
perl -CSD /epics/base-7-0-1-1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ..//..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=..//.. \
make[2]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreySupport/O.linux-x86_64'
Installing generic include file ..//../include/AVIRecorder.h
mkdir ../../include
Installing generic include file ..//../include/BusManager.h
Installing generic include file ..//../include/Camera.h
Installing generic include file ..//../include/CameraBase.h
Installing generic include file ..//../include/Error.h
Installing generic include file ..//../include/FlyCapture2.h
Installing generic include file ..//../include/FlyCapture2Defs.h
Installing generic include file ..//../include/FlyCapture2Platform.h
Installing generic include file ..//../include/GigECamera.h
Installing generic include file ..//../include/Image.h
Installing generic include file ..//../include/ImageStatistics.h
Installing generic include file ..//../include/TopologyNode.h
Installing generic include file ..//../include/Utilities.h
Installing libflycapture.so
mkdir ../../lib
mkdir ../../lib/linux-x86_64
Installing libflycapture.so.2
Installing libflycapture.so.2.9.3.43
make[2]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreySupport/O.linux-x86_64'
make[1]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreySupport'
make -C ./pointGreyApp install
make[1]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp'
make -C ./src install
make[2]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp/src'
perl -CSD /epics/base-7-0-1-1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp/src/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/epics/base-7-0-1-1/include/compiler/gcc -I/epics/base-7-0-1-1/include/os/Linux -I/epics/base-7-0-1-1/include -I/epics/synApps/support/asyn-4-33/include -I/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/Linux -I/epics/synApps/support/areaDetector-3-2/ADSupport/include -I/epics/synApps/support/areaDetector-3-2/ADCore/include -MM -MF pointGrey.d ../pointGrey.cpp
Installing dbd file ../../../dbd/pointGreySupport.dbd
mkdir ../../../dbd
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/epics/base-7-0-1-1/include/compiler/gcc -I/epics/base-7-0-1-1/include/os/Linux -I/epics/base-7-0-1-1/include -I/epics/synApps/support/asyn-4-33/include -I/epics/synApps/support/areaDetector-3-2/ADSupport/include/os/Linux -I/epics/synApps/support/areaDetector-3-2/ADSupport/include -I/epics/synApps/support/areaDetector-3-2/ADCore/include -c ../pointGrey.cpp
../pointGrey.cpp:245:1: error: narrowing conversion of '(FlyCapture2::PixelFormat)2147483648u' from 'unsigned int' to 'int' inside { } [-Wnarrowing]
/epics/base-7-0-1-1/configure/RULES_BUILD:237: recipe for target 'pointGrey.o' failed
make[3]: *** [pointGrey.o] Error 1
make[3]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp/src/O.linux-x86_64'
/epics/base-7-0-1-1/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp/src'
/epics/base-7-0-1-1/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/epics/synApps/support/areaDetector-3-2/ADPointGrey/pointGreyApp'
/epics/base-7-0-1-1/configure/RULES_DIRS:84: recipe for target 'pointGreyApp.install' failed
make: *** [pointGreyApp.install] Error 2
- Re: ADPointGrey with AD3-2, and base-7.0.1.1 Shen, Guobao
- ADPointGrey with AD3-2, and base-7.0.1.1 Gofron, Kazimierz
- Re: ADPointGrey with AD3-2, and base-7.0.1.1 Mark Rivers
Re: Radiation Monitors Anton Derbenev
Security Hardening for EPICS/RTEMS Gedare Bloom
<2018>
2025
2026
<2018>
2025
2026
ANJ, 23 Apr 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
