1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NSLS-II Debian Repository in 2018
To: Christoph Schroeder <[email protected]>
Date: Wed, 25 Apr 2018 16:01:45 -0400
Hello Christoph,
that is a very good question as while there is some practice in that regard, there are cases every now and then when things are done in a different manner which then cause more things to be done in a different manner.
With versions, we want to consider:
- Upstream version (increased with new upstream)
- Debian revision (increased with debianization changes in epicsdeb)
- Debian distribution (depends on the package build target)
- Builder upload (when multiple uploads are performed for our builder for whatever reason, version must increase)
Upstream version and Debian revision numbers are derived from epicsdeb. On top of that, we optionally add other two. Currently for the new repository setup, everything is built for jessie as following:
If the package is not native, it is <upstream>-<revision>.<upload>, e.g. devlib2 is 2.8-1.1.
If the package is native, it is <upstream>+nmu<upload>, e.g. epics-debhelper is 8.17+nmu1.
There is no distribution specification as if jessie is "implicitly" considered to be "baseline". Now, when building for stretch, we should make sure that versions there are "greater" to ensure proper package update... Thus, it's better to have all aforementioned numbers included in the version. The proposed format for packages built from now on is:
For not native packages: <upstream>-<revision>+<distribution>u<upload>, e.g. new devlib2 build would be 2.8-1+deb9u1
For native packages: <upstream>+<distribution>+nmu<upload>, e.g. new epics-debhelper build would be 8.17+deb9+nmu1
I presume it will enable consistent version advancement in all four categories. System upgrades and backports/fixes are not something which we have happening terribly often, but if they do...
Any comments on the matter are welcome.
Anton.
On Mon, Apr 23, 2018 at 5:37 AM, Christoph Schroeder <[email protected]> wrote:
Hi Anton,
as you might know our local repository is mostly a clone of yours + a few HZB customized packages. We would like to fill our new stretch repository now and want to stay compatible with your naming scheme. Do you already have a plan how to name the versions of your packages?
Best regards,
Christoph
On 04/03/2018 07:52 PM, Anton Derbenev wrote:
Hello everyone,
some recent updates on NSLS-II repository structure:
1) As planned, there will be 'Legacy' repository nicknamed 'epics' (packages for Debian 5,6,7,8 Base 3.14), and the 'Current' repository nicknamed 'epicsdeb' (packages for Debian 8 and further 9, now Base 3.15).
2) An important change is that the Lab is moving its public-facing naming to a three-part domain names. It means that by the plan the current repository, http://epics.nsls2.bnl.gov/debian/, is to be available as http://epics.bnl.gov/debian/. The new repository will be available as http://epicsdeb.bnl.gov/debian/.
We'll provide more updates as those changes commence.
Anton.
(bb|[^b]{2})
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
https://www.helmholtz-berlin.de
Re: NSLS-II Debian Repository in 2018 Ralph Lange
Prev: Re: Problem with autosave module making it crash at random basis. Ronald L. Sluiter
Next: RE: ADPointGrey with AD3-2, and base-7.0.1.1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NSLS-II Debian Repository in 2018 Christoph Schroeder
Next: Re: NSLS-II Debian Repository in 2018 Ralph Lange
ANJ, 26 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
