1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS BOY enum local PV
Date: Thu, 26 Apr 2018 17:32:17 +0000
Is it possible to create a local enum PV in CSS that can be used as the PV for a Combo widget that also gets its items from the PV?
I have a PV in an IOC that is creating a list of strings that I would like to use to populate the items of a Combo widget. However, the list may have more than 16 items, so using a normal enum PV with the Combo widget won’t work. I would like to put the list into a local PV that can then be used in the Combo widget to populate its items. I have tried setting the items in a combo widget from a script, but it wasn’t behaving properly.
Thank you,
--Ray
Re: CSS BOY enum local PV Kasemir, Kay
Prev: RE: Possible deadlock issue with asyn layer? Mark Rivers
Next: Re: CSS BOY enum local PV Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stringin - asynOctedRead type how to set string length Mark Rivers
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
