1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stringin - asynOctedRead type how to set string length
To: Pilar Gil Jaldo <[email protected]>
Date: Tue, 5 Jun 2018 12:19:04 +0000
Hi Pilar,
Since you want to use asyn device support I think you must use the waveform record. The lsi and lso records that Ralph mentioned do not currently have asyn device support.
Sent from my iPhone
On Jun 5, 2018, at 5:48 AM, Pilar Gil Jaldo <[email protected]<mailto:[email protected]>> wrote:
Hello Mark,
I would like to send a string which length is bigger than 40.
But as Ronaldo has mentioned, maybe it is better to try it using a waveform.
Thank you very much for your answers!
Pilar
On 05/06/18 12:46, Mark Rivers wrote:
I would like to know if it is possible to set the size of stringin record which type is DTYP=asynOctetRead.
Do the stringin records have a parameter such as "LEN" or something similar?
No, I don't think the stringin record has that.  Why do you want it, what are you trying to do?
From: [email protected]<mailto:[email protected]> <[email protected]><mailto:[email protected]> on behalf of Pilar Gil Jaldo <[email protected]><mailto:[email protected]>
Sent: Tuesday, June 5, 2018 4:53 AM
To: [email protected]<mailto:[email protected]>
Subject: Stringin - asynOctedRead type how to set string length
Hello,
I have been looking in the documentation and I have not found this information.
Thank you very much in advance!
Pilar
Pilar Gil Jaldo
Embedded SW Engineer
[email protected]<mailto:[email protected]><mailto:[email protected]><mailto:[email protected]> - Seven Solutions<https://www.sevensols.com><https://www.sevensols.com>
"This e-mail and any materials attached here to, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are confidential. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it."
[http://sevensols.com]<http://sevensols.com>
Pilar Gil Jaldo
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please immediately notify us via e-mail and delete it.
Modify checkbox value from a table widget Pilar Gil Jaldo
Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
Re: Stringin - asynOctedRead type how to set string length Mark Rivers
Re: Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
Prev: Re: Stringin - asynOctedRead type how to set string length Mark Rivers
Next: Re: Stringin - asynOctedRead type how to set string length Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stringin - asynOctedRead type how to set string length Ralph Lange
Next: CSS BOY enum local PV Gregory, Ray
ANJ, 06 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
