Hi Avinder,
What version of ADProsilica are you using? The conversion from Bayer to RGB is handled in the ADProsilica driver (prosilica.cpp) using the pvAPI library.
There is a PV you need to set, $(P)$(R)BayerConvert. It is in the lower-left of the medm prosilica.adl screen-shot in the documentation here:
http://cars9.uchicago.edu/software/epics/prosilicaDoc.html
You should set BayerConvert=RGB1. Then the output images will be in RGB1 format which the ffmpeg plugin and viewer should handle fine. Using Bayer mode with conversion in the driver like this is a good idea because it reduces the network bandwidth of the camera by a factor of 3.
This conversion from Bayer to RGB1 was moved from the ColorConvert plugin into the ADProsilica driver in R2-0 of ADProsilica (March, 2014) as documented here:
https://github.com/areaDetector/ADProsilica/blob/master/RELEASE.md
This conversion is also supported in the ADPointGrey driver.
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Thursday, May 3, 2018 10:37 AM
To: tech-talk
Subject: Bayer to RGB areaDetector
Dear tech-talk,
Using areaDetector, I have been trying to use the Bayer color mode with a Mako G507C camera at DLS, but to no avail.
When using either the Mono or RGB mode, I see an updated image on the ffmpegViewer screen, but not with Bayer mode.
I tried using the NDPluginColorConvert plugin; converting Bayer color mode to RGB1 (or even Mono) but this also causes the ffmpegViewer stream to stop.
Looking in the NDPluginColorConvert.cpp in ADCore/ADApp/pluginSrc, it depends on PVAPI to deal with debayering, and this was a library from Prosilica, which is a proprietary library, but not in ADCore anymore.
There is demosaicing function in OpenCV that can convert a bayer format to RGB.
My question is: could ADCore depend on OpenCV in order for the color convert plugin bayer feature to work?
If not, could we use the OpenCV method in a separate support module (we have one at DLS called adOpenCV)?
For info; I am using ADCore 2-6 and ffmpegServer 3-1
Cheers,
Arvinder Palaha
Beamline Control Systems
DH G.63
T: +44-(0)1235-77-8137
E: [email protected]
- Bayer to RGB areaDetector [email protected]
Re: Request: Survey of EPICS PVA ( a.k.a EPICS V4) users Mark Rivers
<2018>
2025
2026
Fw: Bayer to RGB areaDetector [email protected]
<2018>
2025
2026
