1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: S7 300 & 1500 PLC family compatibilites with s7plc EPICS device support
Date: Mon, 7 May 2018 05:40:06 +0000
Dear PLC EPICS & PLCs users,
After reviewing EPICS using SLS s7plc driver PDF document: http://epics.web.psi.ch/software/s7plc/YHLhtcPLCa.pdf, and Dirk Zimoch PLC EPICS Device support, it seems to me that at the end is a question of mapping the PLC I/Os in the DataBlocks, that will be accessible through Ethernet using TCP/IP. Actual s7plc EPICS device support, supports “new” (I mean since 2007) S7-300 and s7-1500 PLCs, using TIA portal for programming them? Or shall be modified part of the device support?... My general question is: is there any restriction on both families (S7-300 & S7-1500) to be supported with the actual s7plc device support?
Thank you very much in advance
Regards
Diego
P Please consider the environment before printing this e-mail.
This message including any attachments may contain confidential information, according to our Information Security Management System, and intended solely for a specific individual to whom they are addressed. Any unauthorised copy, disclosure or distribution of this message is strictly forbidden. If you have received this transmission in error, please notify the sender immediately and delete it. Thank you.
Este mensaje, y en su caso, cualquier fichero anexo al mismo, puede contener información clasificada por su emisor como confidencial en el marco de su Sistema de Gestión de Seguridad de la Información siendo para uso exclusivo del destinatario, quedando prohibida su divulgación copia o distribución a terceros sin la autorización expresa del remitente. Si Vd. ha recibido este mensaje erróneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboración.
Esta mensagem, incluindo qualquer ficheiro anexo, pode conter informação confidencial, de acordo com nosso Sistema de Gestão de Segurança da Informação, sendo para uso exclusivo do destinatário e estando proibida a sua divulgação, cópia ou distribuição a terceiros sem autorização expressa do remetente da mesma. Se recebeu esta mensagem por engano, por favor avise de imediato o remetente e apague-a.
Obrigado pela sua colaboração.
Prev: RE: Question regarding the usage of devlib2 Kline, David
Next: Re: Question regarding the usage of devlib2 Jörn Dreyer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Job Opening at Fermilab, Accelerator Controls Dennis Nicklaus
Next: error calling PVUtil.getString() Gregory, Ray
ANJ, 07 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
