1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question regarding the usage of devlib2
To: [email protected]
Date: Mon, 07 May 2018 10:37:14 +0200
Hi Michael,
thanks for the response.
Am Freitag, 4. Mai 2018, 21:20:19 CEST schrieb Michael Davidsaver:
> Did you see the 'uio_pci_generic' driver which comes with Linux, and my
> 'pci_generic_msi' variant in devlib2?
Yes, I saw it. But It's not an option for me, as I'm going to setup a system
that needs to be ready right after every reboot of the PC. The setup I'm
working on should be as much automatic as possible, so even an inexperienced
user can copy it.
> Which ones would you find useful?  I didn't port them over because, in
> hindsight I'm not sure they were so helpful to me.
In principle all of them. My device has 8, 16 and 32 bit registers.
> The original goal was to prevent unintentional access with an incorrect
> width. eg. Using a 32-bit read of a 16-bit register.  In practice with
> mrfioc2 this was a waste.  Due to the strict recipe needed to work with
> both vme and pci, only 32-bit reads could be used.
That's true, so one would make the 8 and 16 bit function by an #ifdef
construct invisible on VME systems.
> Also in hindsight, the BITSET/CLR read-modify-write macros are a recipe for
> race conditions if used without preventing concurrent access (eg. interrupt
> disable or mutex).  This convenience was a little too convenient.
I don't know of a way to disable interrupts from userspace. So this functions
would require an implementation of an iocl in the kernel driver.
For my device I could use of course the PLX SDK as it is based on a PLX chip
for the PCI Interface. Yes it still uses PCI not PCIe. :( It becomes hard to
find a mainboard with such interface nowadays. But the use of the PlxSDK would
complicate the installation more that I am willing to accept.
> > Should these macros not be part of devlib2? This way other modules could
> > profit from this work much easier. Pulling these files into my project
> > would require to install the mrfio2 module even if I do not have the
> > hardware. Not thinking about license conflicts that might arise if I copy
> > the code over to my project.
> mrfioc2 uses the same EPICS open license as devlib2, and Base itself.  So I
> don't think that this aspect will make your life more complicated than it
> already is (if you're thinking about licensing).
My worry was because some of the files (e.g. mrfIoOopsDef.h)  do not have the
License reference header included, so the licensing is not clear.
Jörn Dreyer
Question regarding the usage of devlib2 Jörn Dreyer
Re: Question regarding the usage of devlib2 Michael Davidsaver
Prev: S7 300 & 1500 PLC family compatibilites with s7plc EPICS device support Diego Sanz Hernando
Next: Re: NSLS-II Debian Repository in 2018 Carlos Pascual
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Question regarding the usage of devlib2 Kline, David
Next: Job Opening at Fermilab, Accelerator Controls Dennis Nicklaus
ANJ, 07 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
