1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MCA7-7: Problems to read PV mca
From: Douglas Henrique C. de Araújo <[email protected]>
To: [email protected]
Date: Tue, 8 May 2018 16:27:26 -0300
I installed the support mca7-7 to use a X-123SDD Detector using the MCA Amptek Driver. The IOC starts correctly and the medm screen Amptek.adl works perfectly, but I'm having problem to read a PV mca1.
In the medm screen mca.adl the graph don't show any data and return the follow message: The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES. If I use "caget" in this PV, I have the same problem.
But, if I limit the number of elements of array until 4095 using: caget -# 4095 mcaTest:mca1 for example, the pv return a correct value. I put a very high value in variable EPICS_CA_MAX_ARRAY_BYTES="999999999999", but it still didn't work.
Has anyone had this kind of problem? Any idea how to debug/solve this?
Best Regards
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br
Re: MCA7-7: Problems to read PV mca Hugo Slepicka
Prev: RE: OPI script and Display Builder Gregory, Ray
Next: Re: MCA7-7: Problems to read PV mca Hugo Slepicka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
