1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MCA7-7: Problems to read PV mca
From: Douglas Henrique C. de Araújo <[email protected]>
To: Hugo Slepicka <[email protected]>
Cc: [email protected]
Date: Wed, 9 May 2018 08:29:36 -0300
Hi Hugo,
thank you for the answer.
The problem was in the configuration on Server, I'm using a docker container to run IOC (Server) and another container to run  the medm (Client), and I was setting the variable only on the client. Now worked perfectly.
Regards
and thank you again.
Em 08-05-2018 16:42, Hugo Slepicka escreveu:
Hi Douglas,
Do you have the EPICS_CA_MAX_ARRAY_BYTES also defined before booting our IOC?
You need the configuration on the Client and Server to be correct.
Cheers,
Hugo
On Tue, May 8, 2018 at 12:27 PM Douglas Henrique C. de Araújo <[email protected]> wrote:
I installed the support mca7-7 to use a X-123SDD Detector using the MCA
Amptek Driver. The IOC starts correctly and the medm screen Amptek.adl
works perfectly, but I'm having problem to read a PV mca1.
In the medm screen mca.adl the graph don't show any data and return the
follow message: The requested data transfer is greater than available
memory or EPICS_CA_MAX_ARRAY_BYTES. If I use "caget" in this PV, I have
the same problem.
But, if I limit the number of elements of array until 4095 using: caget
-# 4095 mcaTest:mca1 for example, the pv return a correct value.
I put a very high value in variable
EPICS_CA_MAX_ARRAY_BYTES="999999999999", but it still didn't work.
Has anyone had this kind of problem? Any idea how to debug/solve this?
Best Regards
Douglas Henrique C. de Araujo
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1228
www.lnls.br
www.lnls.br
MCA7-7: Problems to read PV mca Douglas Henrique C . de Araújo
Re: MCA7-7: Problems to read PV mca Hugo Slepicka
Prev: Keithley 2634B Source Meter [email protected]
Next: RE: Keithley 2634B Source Meter Kline, David
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MCA7-7: Problems to read PV mca Hugo Slepicka
Next: Keithley 2634B Source Meter [email protected]
ANJ, 09 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
