1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: devAsynUInt32Digital: add parameter for shifting?
To: "'Konrad, Martin'" <[email protected]>
Date: Wed, 9 May 2018 17:19:31 +0000
Hi Konrad,
I suggest you create an issue in asyn on Github.
My questions:
Would we use the existing asynMask syntax but change "mask" to be something like 0x0F0;8  where the bits before the ; are the mask and the bits after are the shift?
field(INP,"@asynMask(portName,addr,mask,timeout)drvParams")
Or do we make a new asynMaskShift syntax like this?
field(INP,"@asynMaskShift(portName,addr,mask,shift,timeout)drvParams")
Would this apply to longin and longout records?  Any other records that should support this syntax?
For longin first the mask is done in the driver and then the shift is done in device support?
For longout first the shift is done in device support and then the mask is done in the driver?
Is this a common enough use case to justify the change?
-----Original Message-----
Sent: Wednesday, May 9, 2018 8:02 AM
Subject: devAsynUInt32Digital: add parameter for shifting?
Hi Mark,
devAsynUInt32Digital currently supports the following parameters:
We are reading out a bunch of 32 bit registers containing smaller numbers like 4x 8 bit. The mask allows us to pick a subset of bits but the generic device support doesn't seem to allow us to shift them. To make that happen we are currently using an additional calc record. I'm wondering if this use case is common enough to justify adding another parameter for shifting?
-Martin
Martin Konrad
High Performance Controls Team Leader
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
devAsynUInt32Digital: add parameter for shifting? Konrad, Martin
Prev: Re: devAsynUInt32Digital: add parameter for shifting? Konrad, Martin
Next: EDM X/Y Plot segfaults Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
