1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CSS Boy Text Input widget perform Action after value change
To: "Gregory, Ray" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 May 2018 05:13:16 +0000
The only widget action supported in CSS is the mouse click. If you want to process the text in the text input, use a button and a script as the action. You can do something like this python script
text_input = display.getWidget('Widget name goes here')
text = text_input.getValue() # or text_input.getPropertyValue('text')
And then you can process the text as you want.
Best Regards,
Abdalla.
From: [email protected] [mailto:[email protected]] On Behalf Of Gregory, Ray
Sent: Wednesday, May 09, 2018 9:08 PM
To: [email protected]
Subject: CSS Boy Text Input widget perform Action after value change
In a CSS Boy OPI I have a Text Input widget, and I would like to trigger an action whenever the user changes the value/presses the enter button. Just adding the desired Action to the Behavior does not appear to trigger the action when the user presses Enter. Can you please tell me what I am missing?
Thank you,
--Ray
Re: CSS Boy Text Input widget perform Action after value change Luca Cavalli
CSS Boy Text Input widget perform Action after value change Gregory, Ray
Prev: Smaract MCS2 Motor Record Lentz, Zachary L
Next: Re: CSS Boy Text Input widget perform Action after value change Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS Boy Text Input widget perform Action after value change Gregory, Ray
ANJ, 10 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
