Hi Doug,
The number of points store for each live PV data is 40000 points.
This is currently hard coded at that value.
For the next release I can certainly increase this value and/or make
it controllable via an environment variable.
Regards
Andrew C. Starritt | Leader Accelerator and Support Systems | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Thursday, 17 May 2018 8:00 AM
To: [email protected]
Subject: QEgui strip chart question
Hello,
I'm running a test setup for the QEgui tools as a possible replacement for
the EPICS striptool. The strip chart runs perfectly except for one issue.
The data cuts off after a certain amount of time depending on the number
of channels I am plotting. This is only live data haven't tried the
archive look up yet. So for one channel I get about three days of
plotting. For nine channels I get about one and a half hours. I assume
this has to do with a buffer setting somewhere but after days of searching
I have not been able to find it.
Any help would be greatly appreciated.
Thank you in advance,
Doug Lormand
- QEgui strip chart question marc . lormand
Re: Amptek IOC: Problem with subnet Andrew Johnson
EPICS control of an Edwards STP turbomolecular pump Lucock, Richard M
<2018>
2025
2026
Question regarding asynParamInt32Array Jörn Dreyer
<2018>
2025
2026
