1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Amptek IOC: Problem with subnet
To: Mark Rivers <[email protected]>, Douglas Henrique C. de Araújo <[email protected]>
Date: Thu, 17 May 2018 13:26:09 -0500
On 05/17/2018 01:19 PM, Mark Rivers wrote:
> I looked at the code a bit and I believe that their software uses a
> broadcast to find available modules even you specify the IP address
> of the module you want. The broadcasts won’t go between subnets.
If this is a standard UDP broadcast and you know (or can find out) what
port number(s) they are using, you may be able to run a program on a
machine that has interfaces in both subnets to forward the broadcast
traffic between them. The one we've used is called UDP Broadcast Packet
Relay:
    https://www.joachim-breitner.de/udp-broadcast-relay/
HTH,
- Andrew
Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Re: Amptek IOC: Problem with subnet Hugo Slepicka
Re: Amptek IOC: Problem with subnet Douglas Henrique C . de Araújo
Re: Amptek IOC: Problem with subnet Mark Rivers
Prev: Re: Amptek IOC: Problem with subnet Mark Rivers
Next: RE: QEgui strip chart question Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: Reminder: June EPICS Meeting at Argonne Andrew Johnson
ANJ, 18 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
