1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Store 64-bit integer in asyn parameter library?
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 18 May 2018 18:20:24 +0000
I think the bit rates are normally in the range of 10,000 to 100,000 and unlikely to exceed 32 bit integer.
Sent from my iPhone
> On May 18, 2018, at 2:15 PM, J. Lewis Muir <[email protected]> wrote:
>> On 05/18, Mark Rivers wrote:
>> What value does this represent in the vendor library? Sometimes a
>> double can be used. It can exactly represent a 52 bit integer.
> The average bitrate of an audio or video stream.  The library is FFmpeg,
> the value is AVCodecContext::bit_rate:
>  http://www.ffmpeg.org/doxygen/4.0/structAVCodecContext.html#a6b53fda85ad61baa345edbd96cb8a33c
> Lewis
Re: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Re: Store 64-bit integer in asyn parameter library? Mark Rivers
Prev: Re: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Next: Re: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
