1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Store 64-bit integer in asyn parameter library?
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 18 May 2018 14:25:31 -0500
On 05/18, Mark Rivers wrote:
> I think the bit rates are normally in the range of 10,000 to 100,000
> and unlikely to exceed 32 bit integer.
Of course, you could have some crazy bitrate like 2,985,984,000 bps
(uncompressed 24-bit color 1080p at 60 fps) that would not fit, but I
guess I'm unlikely to run into that, so I'll just do the conversion from
64-bit integer to 32-bit integer and return an error if it won't fit.
Lewis
Re: Store 64-bit integer in asyn parameter library? Mark Rivers
Re: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Prev: Re: Store 64-bit integer in asyn parameter library? Mark Rivers
Next: Re: Store 64-bit integer in asyn parameter library? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
