The Travis CI build for asyn is failing with the following error when trying to get packages from the NSLS2 Debian repository. This was previously working fine and the asyn travis script has not changed. Do I need to change something in this script?
$ git clone --depth=50 --branch=master https://github.com/epics-modules/asyn.git epics-modules/asyn
Cloning into 'epics-modules/asyn'...
remote: Counting objects: 978, done.
remote: Compressing objects: 100% (634/634), done.
remote: Total 978 (delta 450), reused 667 (delta 324), pack-reused 0
Receiving objects: 100% (978/978), 1.33 MiB | 13.51 MiB/s, done.
Resolving deltas: 100% (450/450), done.
$ cd epics-modules/asyn
$ git checkout -qf 191a9e58c20de9970fbe3dc5b204ff5e713ca2ac
Setting environment variables from .travis.yml
$ export EPICS_BASE=/usr/lib/epics
$ export EPICS_HOST_ARCH=linux-x86_64
$ export CXX=g++
$ export CC=gcc
$ gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
0.21s$ curl http://epics.nsls2.bnl.gov/debian/repo-key.pub | sudo apt-key add -
gpg: no valid OpenPGP data found.
The command "curl http://epics.nsls2.bnl.gov/debian/repo-key.pub | sudo apt-key add -" failed and exited with 2 during .
Your build has been stopped.
- Re: NSLS2 Debian problem? Jani Hakala
Re: Store 64-bit integer in asyn parameter library? Luca Cavalli
<2018>
2025
2026
Job Opening at Fermilab, Accelerator Instrumentation Department Dennis Nicklaus
<2018>
2025
2026
