1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Is it possible to make an IOC for an HTTP device?
From: Freddie Akeroyd - UKRI STFC <[email protected]>
To: "'J. Lewis Muir'" <[email protected]>, "'Sobhani, Bayan'" <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 22 May 2018 22:19:48 +0000
As Lewis says, Stream device can work for many cases - there is an example at http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#web
If you find you need something more complicated, drop me a direct email as I have had need to combine asyn with libxml2, curl & htmltidy in the past to scrape a web page using XPath expressions and I might be able to point you at something usable
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of J. Lewis Muir
Sent: 22 May 2018 23:05
To: Sobhani, Bayan
Cc: [email protected]
Subject: Re: Is it possible to make an IOC for an HTTP device?
On 05/22, Sobhani, Bayan wrote:
> I am looking at this device:
> https://www.embeddeddatasystems.com/HA7Net--Ethernet-1-Wire-Host-Adapt
> er_p_22.html
> It says that communication is done with the HTTP protocol  - is this significant? Would it be doable for me to make an IOC that uses let's say StreamDevice to communicate with this?
It just depends on what the device's communication interface is like.
You said it's the HTTP protocol, but you need to know what the requests look like (e.g., what resource do you request with an HTTP GET) and what responses look like.  If things are really simple, you could use StreamDevice.  Even if the responses are real web pages, you could still potentially use StreamDevice if you can figure out how to match on the parts of the response that you want.  This is known as screen scraping or web scraping; it's a hack, but it could be sufficient.  If it returns a complex HTML document, complex XML document, or some nontrivial binary response, etc., then you would want to move beyond StreamDevice and write something (probably based on asyn) that can actually properly parse the response.
Lewis
Re: Is it possible to make an IOC for an HTTP device? Eric Norum
Is it possible to make an IOC for an HTTP device? Sobhani, Bayan
Re: Is it possible to make an IOC for an HTTP device? J. Lewis Muir
Prev: Re: Is it possible to make an IOC for an HTTP device? J. Lewis Muir
Next: Re: Is it possible to make an IOC for an HTTP device? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 22 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
