1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: msi "Could not open" error on Windows with file absolute path
To: "J. Lewis Muir" <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 23 May 2018 06:20:49 +0200
On 23/05/18 00:57, J. Lewis Muir wrote:
On 05/22, Johnson, Andrew N. wrote:
Try using forward slashes instead of back-slashes, and also enclose the whole file path inside double quotes.
Bingo!  That worked!  Thank you!
Is this practice generally recommended for all Windows pathnames in
an EPICS context?  Perhaps I should narrow this to all pathnames that
do not start with the pathname component separator (i.e., slash or
backslash)?  I'm not sure.  The idea is to avoid breaking any Windows
commands that take options that start with a slash and might get
confused. (?) But maybe if all pathnames eventually get turned into
absolute pathnames, everything works out.  I've been faithfully using
the backslash to separate path components, but I noticed that a lot
of the pathnames generated by the EPICS build system include slashes,
so many of the pathnames end up containing a mix of backslashes and
slashes; it looks horrible, but it seems to work (except for msi).
Say I'm configuring the asyn EPICS module in <asyn>\configure\RELEASE,
is it better to set "SUPPORT=C:/opt/epics-module" and
"EPICS_BASE=C:/opt/epics-base" rather than using the normal Windows
backslash path component separator?  For me, I think it's going to
be essential since I'd like to use macros in the file directive in a
template substitution file, and as your suggestion has shown, pathnames
must use backslashes, not slashes, in order for msi to work!
What about in <EPICS Base>\startup\win32.bat?  I'm guessing everything
in there should still be using the backslash because all of those values
are being interpreted by Windows programs.  Although, just looking at it
again, I see in the optional environment variables section commented out
lines like "set HOME=c:/users/jba".  Maybe that's just for use with a
Cygwin program, though; I don't know.
The windows system can use forward - slashes when dealing with file
names (like opening a file).
This is documented here:
https://msdn.microsoft.com/en-us/library/windows/desktop/aa365247(v=vs.85).aspx
My conclusion is, that C:/something should work, as long as the length of the path stays below MAX_PATH.
BTW, it also worked without the double quotes.  This is consistent with
the template file syntax at:
   https://epics.anl.gov/base/R3-14/12-docs/AppDevGuide/node7.html#SECTION007220000000000000000
which says:
   The file name may appear inside double quotation marks; these are
   required if the name contains any characters that are not in the
   following set, or if it contains environment variable macros of the
   form ${ENV_VAR_NAME} which are to be expanded before the file is
   opened:
     a-z A-Z 0-9 _ + - . / \ : ; [ ] < >
Since the pathname didn't contain any characters outside of the above
set, and since it didn't contain an environment variable macro of the
specified form, I concluded that double quotes were not needed.
Thanks!
Lewis
Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Re: msi "Could not open" error on Windows with file absolute path Johnson, Andrew N.
Prev: Re: Is it possible to make an IOC for an HTTP device? Rod Nussbaumer
Next: Re: xxxRecord.c warning about epicsFloat64 to float conversion Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
Next: Re: msi "Could not open" error on Windows with file absolute path J. Lewis Muir
ANJ, 23 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
