1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Installation of RTEMS and EPICS on MVME6100
To: <[email protected]>
Cc: 이충산 <[email protected]>
Date: Fri, 25 May 2018 16:03:57 +0900 (KST)
I have some questions about configuration of MVME6100.
My purpose is to run EPICS IOC on VME-EVR-230, VME-EVG-230 and MVME6100.
When I try to download RTEMS boot file from server to MVME6100, there is an error message for 'nfsMount' on MVME6100 side.
(I got these messages via Debug port on MVME6100), And then nfs client didn't mount to nfs server.
I don't know what problem is.
Is anyone check my log and environments what trouble is?
my log and environments are below:
==hardware==
1) MVME6100
2) VME-EVR-230
3) VME-EVG-230
==software===
1) Scientific Linux 6.5 (server)
2) EPICS: R3.14.12 (server)
3) RTEMS: 4.10.2 (server)
4) BSP: beatnik (server)
1. boot log on MVME6100
========== boot log on MVME6100 ==========
Copyright(C)2008-2009,Emerson Network Power-Embedded Computing,Inc.
All Rights Reserved
Copyright Motorola Inc. 1999-2007, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 2.3 RM01
Fri Jan 23 14:47:54 MST 2009
MPU-Type             =MPC74x7
MPU-Int Clock Speed  =1266MHz
MPU-Ext Clock Speed  =133MHz
MPU-Int Cache(L2) Enabled, 512KB, L2CR =C0000000
MPU-Ext Cache(L3) Enabled, 2MB, 211MHz, L3CR =DC026300
PCI bus instance 0   =64 bit, 133 Mhz, PCI-X
PCI bus instance 1   =64 bit, PCI
Reset/Boot Vector    =Flash1
Local Memory Found   =80000000 (&2147483648)
User Download Buffer =006B7000:008B6FFF
MVME6100> tftpget -s192.168.2.229 -c192.168.2.240 -fepics/demo/bin/RTEMS-beatnik/test.boot
Network Loading from: /dev/enet0
Loading File: epics/demo/bin/RTEMS-beatnik/test.boot
Load Address: 006B7000
Download Buffer Size = 00200000
Client IP Address      = 192.168.2.240
Server IP Address      = 192.168.2.229
Gateway IP Address     = 192.168.0.1
Subnet IP Address Mask = 255.255.252.0
Network File Load in Progress...
Bytes Received =&1706484, Bytes Loaded =&1706484
Bytes/Second   =&1706484, Elapsed Time =1 Second(s)
MVME6100>-----------------------------------------
config addr is 0xF1000CF8
config data is 0xF1000CFC
Welcome to RTEMS rtems-4.10.2(PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-2173 (S/N E183652)
Bus Clock Freq:   133333333 Hz
CPU Clock Freq:  1266666654 Hz
Memory:          2147483648 bytes
Now BSP_mem_size = 0x7F800000
Configuration.work_space_size = A4D10
Page table setup finished; will activate it NOW...
Going to start PCI buses scanning and initialization
Number of PCI buses found is : 3
MSR 2003032
Exit from bspstart
unable to find the universe in pci config space
Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
Tsi148 Inbound Port Cfg: invalid address/length; must be < 1<<32
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0E000000 0x90000000 A32, SUP, D32, SCT
1:    0x00000000 0x00FF0000 0x9F000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0x9FFF0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0x9E000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
Registering /dev/console as minor 0 (==/dev/ttyS0)
***** Initializing network *****
Startup.
Link detected; attaching mve1
***** Initializing NFS *****
Mount 192.168.2.229:/usr/local/epics on /usr/local/epics
RTEMS-RPCIOD $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RTEMS-NFS $Release$, Till Straumann, Stanford/SLAC/SSRL 2002, See LICENSE file for licensing info.
RPCIO: server '192.168.2.229' not responding - still trying
Unable to contact NFS server - invalid port? (RPC: Timed out)
mount failed: Unknown protocol
rtems_bsdnet_get_ntp() Can't send: Host is down
***** Starting EPICS application *****
Can't open /home: No such file or directory
2.gevshow commend on MOTload
============= gev show =============
MVME6100> gevshow
mot-/dev/enet0-cipa=192.168.2.240
mot-/dev/enet0-sipa=192.168.2.229
mot-/dev/enet0-snma=255.255.252.0
rtems-client-name=BNCT_TIMING
epics-script=/home
mot-/dev/enet0-gipa=192.168.0.1
mot-script-boot
netShut
go
rtems-dns-server=1.1.1.1
mot-/dev/enet0-file=epics/demo/bin/RTEMS-beatnik/test.boot
epics-nfsmount=192.168.2.229:/usr/local/epics:/usr/local/epics
Total Number of GE Variables =10, Bytes Utilized =439, Bytes Free =3153
3. Information on nfs server side
[root@localhost local]# rpcinfo -p 192.168.2.229
   program vers proto   port  service
    100000    4   tcp    111  portmapper
    100000    3   tcp    111  portmapper
    100000    2   tcp    111  portmapper
    100000    4   udp    111  portmapper
    100000    3   udp    111  portmapper
    100000    2   udp    111  portmapper
    100011    1   udp    875  rquotad
    100011    2   udp    875  rquotad
    100011    1   tcp    875  rquotad
    100011    2   tcp    875  rquotad
    100005    1   udp  34798  mountd
    100005    1   tcp  40401  mountd
    100005    2   udp  53440  mountd
    100005    2   tcp  54014  mountd
    100005    3   udp  35346  mountd
    100005    3   tcp  49462  mountd
    100003    2   tcp   2049  nfs
    100003    3   tcp   2049  nfs
    100003    4   tcp   2049  nfs
    100227    2   tcp   2049  nfs_acl
    100227    3   tcp   2049  nfs_acl
    100003    2   udp   2049  nfs
    100003    3   udp   2049  nfs
    100003    4   udp   2049  nfs
    100227    2   udp   2049  nfs_acl
    100227    3   udp   2049  nfs_acl
    100021    1   udp  42432  nlockmgr
    100021    3   udp  42432  nlockmgr
    100021    4   udp  42432  nlockmgr
    100021    1   tcp   4001  nlockmgr
    100021    3   tcp   4001  nlockmgr
    100021    4   tcp   4001  nlockmgr
[root@localhost local]# ifconfig
p3p1      Link encap:Ethernet  HWaddr B4:96:91:04:2A:DD
          inet addr:192.168.2.229  Bcast:192.168.3.255  Mask:255.255.252.0
          inet6 addr: fe80::b696:91ff:fe04:2add/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:3416123 errors:0 dropped:0 overruns:0 frame:0
          TX packets:784304 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:396950516 (378.5 MiB)  TX bytes:462271580 (440.8 MiB)
          Memory:f7600000-f7700000
[root@localhost local]# vi /etc/exports
/usr/local/epics        *(ro,all_squash,no_subtree_check,async)
/usr/local/eldk/eldk/ppc_74xx   *(rw,sync,no_root_squash,secure)
/tftpboot/epics *(ro,sync)
[root@localhost local]# vi /etc/sysconfig/nfs
# Define which protocol versions mountd
# will advertise. The values are "no" or "yes"
# with yes being the default
MOUNTD_NFS_V2="yes"
#MOUNTD_NFS_V3="yes"
[root@localhost local]# uname -a
Linux localhost.localdomain 2.6.32-431.el6.i686 #1 SMP Thu Nov 21 13:48:12 CST 2013 i686 i686 i386 GNU/Linux
Re: Installation of RTEMS and EPICS on MVME6100 Heinz Junkes
Prev: RE: CSS BOY or Display Builder ready-to-run binary? Mark Rivers
Next: Re: benchtop testbeds for EPICS development and testing? Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Next: Re: Installation of RTEMS and EPICS on MVME6100 Heinz Junkes
ANJ, 26 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
