1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BOY or Display Builder ready-to-run binary?
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 25 May 2018 11:12:33 -0500
On 05/24, J. Lewis Muir wrote:
> And attempting to open the app (i.e., cs-studio.exe) on 32-bit Windows 7
> results in a dialog that says:
>   The version of this file is not compatible with the version of Windows
>   you're running.  Check your computer's system information to see
>   whether you need an x86 (32-bit) or x64 (64-bit) version of the
>   program, and then contact the software publisher.
Looking at this issue on Windows more closely, I see x86_64 in the
filename, cs-studio-4.5.7-win32.win32.x86_64.zip, so I take that to mean
it's built for 64-bit Windows, and since the machine I tried this on is
running 32-bit Windows 7, I'm sure that's why it didn't work.  So, my
mistake.  (Too bad there's no 32-bit version for Windows.)
The macOS issue remains.
Lewis
CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Prev: VME configuration : MVME6100 can not map slot x to CR/CSR 유진성
Next: Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Next: Installation of RTEMS and EPICS on MVME6100 유진성
ANJ, 25 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
