1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BOY or Display Builder ready-to-run binary?
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 25 May 2018 12:37:41 -0500
On 05/25, Mark Rivers wrote:
> Yes, it was working earlier today but appears to be down now.
OK, I tried the basic-epics nightly build for 32-bit Windows, and it
worked!  (Actually, it does not come bundled with a JRE, so I had to
install one.  But once I did, then it worked.)
The basic-epics macOS build did not work, unfortunately.  It crashed
with an error dialog that said:
  An error has occurred.
  See the log file /Users/jlmuir/CSS-Workspaces/Default/.metadata/.log.
I've included the contents of that log file at the end of this email.
Lewis
!SESSION 2018-05-25 11:16:33.864 -----------------------------------------------
eclipse.buildId=CSS_EPICS
java.version=10.0.1
java.vendor=Oracle Corporation
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments:  -psn_0_2556528
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -psn_0_2556528
!ENTRY org.eclipse.osgi 4 0 2018-05-25 11:17:40.102
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
  at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:410)
  at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:318)
  at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
  at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:491)
  at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:505)
  at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:204)
  at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:614)
  at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
  at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
  at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
  at org.csstudio.utility.product.Workbench.runWorkbench(Workbench.java:99)
  at org.csstudio.startup.application.Application.startApplication(Application.java:265)
  at org.csstudio.startup.application.Application.start(Application.java:119)
  at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
  at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
  at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
  at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
  at java.base/java.lang.reflect.Method.invoke(Method.java:564)
  at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
  at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
  at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
  at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:124)
  at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:399)
  ... 24 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
  at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:433)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
  at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
  at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
  at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:499)
  ... 26 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2018-05-25 11:17:40.107
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
  at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:450)
  at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:156)
  at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
  at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
  at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
  at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:178)
  at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:99)
  at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:141)
  at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
  at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
  at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
  at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
  at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168)
  at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
  at org.eclipse.osgi.container.Module.doStop(Module.java:634)
  at org.eclipse.osgi.container.Module.stop(Module.java:498)
  at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
  at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
  at java.base/java.lang.Thread.run(Thread.java:844)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.100.v20170421-1418
  ... 21 more
!ENTRY org.eclipse.core.resources 2 10035 2018-05-25 11:17:40.162
!MESSAGE The workspace will exit with unsaved changes in this session.
Re: CSS BOY or Display Builder ready-to-run binary? Kasemir, Kay
CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
RE: CSS BOY or Display Builder ready-to-run binary? Mark Rivers
Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Prev: Re: CSS BOY or Display Builder ready-to-run binary? J. Lewis Muir
Next: Re: CSS BOY or Display Builder ready-to-run binary? Hartman, Steven M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CSS BOY or Display Builder ready-to-run binary? Mark Rivers
Next: Re: CSS BOY or Display Builder ready-to-run binary? Kasemir, Kay
ANJ, 25 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
