> - linux : 2.6.20
What you see is not a mis-configuration. Unfortunately there
is no backend for VME on Linux included in devlib2. Only for
RTEMS or vxWorks.
I know there is at least one implementation out there using a
proprietary Linux driver for a VME bridge (not sure which one).
I've never had access to this.
So your options as I see them are to figure out how to use RTEMS,
or to find/write a Linux driver which devlib2 can be made to use*.
RTEMS is probably the easier route, although as you've found
there is a learning curve.
Michael
* The standard Linux VME userspace module doesn't support interrupts,
and would need modification/replacement as mrfioc2 relies heavily
on interrupts.
On 05/25/2018 08:00 AM, 유진성 wrote:
> Hello
> This question is about configuration of VME-EVG-230 or not.
> Before I use mrfioc2 and devLib2, I didn't change configuration of any pins(GAP*, GA*) on VME-EVG-230.
> I'm not sure that I have to change pins(GAP* and GA*) to load VME-EVG-230 on MVME6100(CPU) or not.
> anyways, I made software environment successfully. there were no error during compiling.
> but, I run EPICS IOC. And then I got problem.
> *figure 1. trouble*
> At that time, mrmEvgSetupVME() can't find EVG on my VME Crate.
> I typed the collect CS/CSR starting Address that is based on MVME6100 reference manual.
> *figure 2. CR/CSR slave address for MVME6100*
> I can't find what is problem(software configuration or hardware setting).
> I'm newbie for VME platform. please, check my log and answer me.
> I'll wait for your reply
> best regards,
> P.S
> Software environment, Hardware environment and log are below:
> ======software======
> - linux : 2.6.20
> - BSP : zImage.initrd.6100.2620.rm01 for MVME6100 from EMERSON
> - devLib2 : 2.9
> - epics : 3.14.12-rc1
> - mfrioc2 : 2.2.0
> =====Hardware=====
> - VME crate : VME 64x
> - CPU : MVME6100
> - EVR : VME-EVR-230
> - EVG : VME-EVG-230
> =====log=======
> -bash-3.2# ../../bin/linux-ppc74xx/mrf st.cmd
> #!../../bin/linux-x86/nsls2evgMrm
> < envPaths
> epicsEnvSet("ARCH","linux-ppc74xx")
> epicsEnvSet("IOC","iocevgmrm")
> epicsEnvSet("TOP","/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/")
> epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
> cd /usr/local/epics/base/modules/instrument/mrfioc2-2.2.0
> ## Register all support components
> #dbLoadDatabase("/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/dbd/mrf.dbd")
> dbLoadDatabase("dbd/mrf.dbd")
> mrf_registerRecordDeviceDriver(pdbbase)
> Warning: IOC is booting with TOP = "/usr/local/epics/base/modules/instrument/mrfioc2-2.2.0/"
> but was built with TOP = "/usr/local/epics/R3.14.12-rc1/modules/instrument/mrfioc2-2.2.0"
> epicsEnvSet("ENGINEER","Jayesh Shah")
> epicsEnvSet("LOCATION","Blg 902 Rm 28")
> bspExtVerbosity=0
> st.cmd -- Line 14 -- Command bspExtVerbosity=0 not found.
> #mrmEvgSetupVME (
> # const char* id, // EVG card ID
> # epicsInt32 slot, // VME slot
> # epicsUInt32 vmeAddress, // Desired VME address in A24 space
> # epicsInt32 irqLevel // IRQ Level
> # epicsInt32 irqVector, // Desired interrupt vector number
> mrmEvgSetupVME(EVG1, 4, 0x200000, 4, 0xC0)
> pdevLibVME is NULL
> Failed to map slot 4 to CR/CSR address 0x00200000
> No EVG in slot 4
> ## Load record instances
> dbLoadRecords("db/vme-evg230.db", "SYS=TST, D=evg:1, EVG=EVG1")
> # BNL specific timing sequence constructor
> #dbLoadRecords("db/nsls2-inj-seqs.db","LN=LN-TS, BR=BR-TS, INJ=TST, EVG=evg:1, SEQ=SoftSeq:0")
> dbLoadRecords("db/iocAdminRTEMS.db", "IOC=mrftest")
> filename="../dbLexRoutines.c" line number=243
> No such file or directory dbRead opening file db/iocAdminRTEMS.db
> # Auto save/restore
> # save_restoreDebug(2)
> # dbLoadRecords("db/save_restoreStatus.db", "P=mrftest:")
> # save_restoreSet_status_prefix("mrftest:")
> # set_savefile_path("{mnt}/as","/save")
> # set_requestfile_path("{mnt}/as","/req")
> # set_pass0_restoreFile("mrf_settings.sav")
> # set_pass0_restoreFile("mrf_values.sav")
> # set_pass1_restoreFile("mrf_values.sav")
> # set_pass1_restoreFile("mrf_waveforms.sav")
> iocInit()
> Starting iocInit
> ## EPICS R3.14.12-rc1 $Date: Mon 2010-11-15 13:59:06 -0600$
> ## EPICS Base built May 15 2018
> ==END==
- Re: VME configuration : MVME6100 can not map slot x to CR/CSR Dirk Zimoch
- VME configuration : MVME6100 can not map slot x to CR/CSR 유진성
Re: Installation of RTEMS and EPICS on MVME6100 Heinz Junkes
Re: EtherCAT newbie question Jeong Han Lee
<2018>
2025
2026
<2018>
2025
2026
