1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ADPvcam: can't create IOC because of missing build (bin) folder
To: Häbel, Catharina <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 May 2018 12:24:07 +0000
Hi Catharina,
I don't think the ADPvCam software will work for that camera.  It is complicated, but PvCam was written by Photometrics.  Photometrics and Princeton Instruments are both part of Roper Scientific, and some older Princeton Instruments cameras do work with PvCam.
However, recent Princeton cameras do not work with PvCam, they only work with the new PICam from Princeton.  PICam is the underlying library for LightField, which is their end-user software.  PICam is free, while LightField costs money.  LightField runs on Windows only.
There are 2 areaDetector drivers that should work with your SOPHIA-X0 camera:
- ADPICam (Windows and Linux, though their Linux support is poorly documented.  It is mentioned in this manual:
ftp://ftp.piacton.com/Public/Manuals/Princeton%20Instruments/PICam%205.x%20Programmers%20Manual.pdf)
- ADLightField (Windows only)
Sent: Monday, May 28, 2018 4:14 PM
To: Häbel, Catharina; [email protected]
Hi Catharina,
> I have used the areaDetector R3-2 and the ADPvCam R2-2, EPICS 3.14.12.4 and Debian 9 to build an IOC for the Princeton SOPHIA-XO Camera.
> But there is no bin folder created as it is the case for e.g. by building an IOC for ADAndor. Any help is welcome.
What architecture are you building for?  ADPvCam only supports 32-bit Linux and Windows architectures, not 64-bit.
It works fine for me to build on the linux-x86 architecture.  Here is the output:
corvette:~/devel/areaDetector/ADPvCam>echo $EPICS_HOST_ARCH
linux-x86
corvette:~/devel/areaDetector/ADPvCam>make -sj clean uninstall
make -C ./configure install
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.vxWorks-ppc32 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. \
    T_A=linux-x86 install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.linux-x86'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.linux-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32 install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.vxWorks-ppc32'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure/O.vxWorks-ppc32'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/configure'
make -C ./pvcamSupport install
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport'
mkdir -p O.Common
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.linux-x86'
Installing generic include file ../../include/pvcam.h
mkdir ../../include
Installing generic include file ../../include/pv_icl.h
Installing OS dependent include file ../../include/os/Linux/master.h
mkdir ../../include/os
mkdir ../../include/os/Linux
Installing libpvcam.so
mkdir ../../lib/linux-x86
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.linux-x86'
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.vxWorks-ppc32'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport/O.vxWorks-ppc32'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamSupport'
make -C ./pvcamApp install
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp'
make -C ./src install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src'
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/makeMakefile.pl O.vxWorks-ppc32 ../../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.linux-x86'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -MM -MF drvPVCamEpics.d  ../drvPVCamEpics.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -MM -MF pvCam.d  ../pvCam.cpp
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.linux-x86'
Installing dbd file ../../../dbd/pvCamSupport.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -c ../pvCam.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -c ../drvPVCamEpics.c
/usr/bin/ar -rc    libpvCam.a         pvCam.o drvPVCamEpics.o
/usr/bin/ranlib libpvCam.a
/usr/bin/g++ -o libpvCam.so -shared -fPIC -Wl,-hlibpvCam.so -L/home/epics/devel/areaDetector-3-2/ADPvCam/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADCore/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADSupport/lib/linux-x86 -L/home/epics/devel/asyn-4-33/lib/linux-x86 -L/usr/local/epics-devel/base-7.0.1/lib/linux-x86            -rdynamic -m32             pvCam.o drvPVCamEpics.o   -lpvcam -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86/libpvCam.so
Installing library ../../../lib/linux-x86/libpvCam.a
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.vxWorks-ppc32'
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include       -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > drvPVCamEpics.d  ../drvPVCamEpics.c
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include       -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCam.d  ../pvCam.cpp
In file included from ../pvCam.cpp:11:
../pvCamSrc.h:36:20: error: master.h: No such file or directory
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src/O.vxWorks-ppc32'
make[3]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/src'
make -C ./Db install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db'
mkdir -p O.Common
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.linux-x86'
Installing template file ../../../db/pvCam.template
mkdir ../../../db
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.linux-x86'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.vxWorks-ppc32'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db/O.vxWorks-ppc32'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp/Db'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/pvcamApp'
make -C ./iocs install
make[1]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs'
make -C ./pvcamIOC install
make[2]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure'
mkdir -p O.Common
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86'
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.linux-x86'
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.vxWorks-ppc32'
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure/O.vxWorks-ppc32'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/configure'
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp'
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
mkdir -p O.Common
make[5]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include  -I../../../../../include/os/Linux -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -MM -MF pvCamAppMain.d  ../pvCamAppMain.cpp
Creating dbd file pvCamApp.dbd
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/corvette/home/epics/devel/asyn-4-33/dbd -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/dbd -I/corvette/home/epics/devel/autosave-5-9/dbd -I/corvette/home/epics/devel/busy-1-7/dbd -I/corvette/home/epics/devel/calc-3-7/dbd -I/corvette/home/epics/devel/seq-2-2-5/dbd -I/corvette/home/epics/devel/sscan-2-11-1/dbd -I/corvette/home/epics/devel/devIocStats-3-1-15/dbd -I/corvette/usr/local/epics-devel/base-7.0.1/dbd -o pvCamApp.dbd pvCamSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDPluginPva.dbd PVAServerRegister.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileJPEG.dbd NDFileNexus.dbd NDFileHDF5.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
perl -CSD /corvette/usr/local/epics-devel/base-7.0.1/bin/linux-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/corvette/home/epics/devel/asyn-4-33/dbd -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/dbd -I/corvette/home/epics/devel/autosave-5-9/dbd -I/corvette/home/epics/devel/busy-1-7/dbd -I/corvette/home/epics/devel/calc-3-7/dbd -I/corvette/home/epics/devel/seq-2-2-5/dbd -I/corvette/home/epics/devel/sscan-2-11-1/dbd -I/corvette/home/epics/devel/devIocStats-3-1-15/dbd -I/corvette/usr/local/epics-devel/base-7.0.1/dbd    -o pvCamApp_registerRecordDeviceDriver.cpp ../O.Common/pvCamApp.dbd pvCamApp_registerRecordDeviceDriver /home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include  -I../../../../../include/os/Linux -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -MM -MF pvCamApp_registerRecordDeviceDriver.d  pvCamApp_registerRecordDeviceDriver.cpp
make[5]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.linux-x86'
Installing created dbd file ../../../dbd/pvCamApp.dbd
mkdir ../../../dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include  -I../../../../../include/os/Linux -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -c pvCamApp_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -D_FILE_OFFSET_BITS=64  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include  -I../../../../../include/os/Linux -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/Linux -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/Linux -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/Linux -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/Linux -I/corvette/usr/local/epics-devel/base-7.0.1/include        -c ../pvCamAppMain.cpp
/usr/bin/g++ -o pvCamApp -Wl,-Bstatic -L/home/epics/devel/areaDetector-3-2/ADPvCam/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADCore/lib/linux-x86 -L/home/epics/devel/areaDetector-3-2/ADSupport/lib/linux-x86 -L/home/epics/devel/asyn-4-33/lib/linux-x86 -L/home/epics/devel/autosave-5-9/lib/linux-x86 -L/home/epics/devel/busy-1-7/lib/linux-x86 -L/home/epics/devel/calc-3-7/lib/linux-x86 -L/home/epics/devel/devIocStats-3-1-15/lib/linux-x86 -L/home/epics/devel/seq-2-2-5/lib/linux-x86 -L/home/epics/devel/sscan-2-11-1/lib/linux-x86 -L/usr/local/epics-devel/base-7.0.1/lib/linux-x86            -rdynamic -m32             pvCamApp_registerRecordDeviceDriver.o pvCamAppMain.o   -lpvCam -lNDPlugin -lADBase -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -ljpeg -lxml2 -lNeXus -lhdf5 -lblosc -lszip -lzlib -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom -Wl,-Bdynamic -lpvcam -lraw1394 -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing created executable ../../../bin/linux-x86/pvCamApp
mkdir ../../../bin/linux-x86
make[5]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.vxWorks-ppc32'
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include   -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/vxWorks -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/vxWorks -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include       -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCamAppMain.d  ../pvCamAppMain.cpp
/usr/local/vw/vxWorks-6.9.4/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/vxWorks.h    -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/vxWorks -I../../../include   -I../../../../../include      -I/corvette/home/epics/devel/asyn-4-33/include     -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include/os/vxWorks -I/corvette/home/epics/devel/areaDetector-3-2/ADSupport/include   -I/corvette/home/epics/devel/areaDetector-3-2/ADCore/include  -I/corvette/home/epics/devel/autosave-5-9/include/os/vxWorks -I/corvette/home/epics/devel/autosave-5-9/include   -I/corvette/home/epics/devel/busy-1-7/include   -I/corvette/home/epics/devel/calc-3-7/include   -I/corvette/home/epics/devel/seq-2-2-5/include   -I/corvette/home/epics/devel/sscan-2-11-1/include  -I/corvette/home/epics/devel/devIocStats-3-1-15/include/os/vxWorks -I/corvette/home/epics/devel/devIocStats-3-1-15/include -I/corvette/usr/local/epics-devel/base-7.0.1/include/compiler/gcc -I/corvette/usr/local/epics-devel/base-7.0.1/include/os/vxWorks -I/corvette/usr/local/epics-devel/base-7.0.1/include       -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9.4/vxworks-6.9/target/h/wrn/coreip -MM > pvCamApp_registerRecordDeviceDriver.d  pvCamApp_registerRecordDeviceDriver.cpp
make[5]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src/O.vxWorks-ppc32'
make[5]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp/src'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/pvcamApp'
make -C ./iocBoot install
make[3]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot'
make -C ./iocPvCam install
make[4]: Entering directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot/iocPvCam'
make[3]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC/iocBoot'
make[2]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs/pvcamIOC'
make[1]: Leaving directory `/home/epics/devel/areaDetector-3-2/ADPvCam/iocs'
corvette:~/devel/areaDetector/ADPvCam>ls iocs/pvcamIOC/bin/linux-x86/
pvCamApp
Note that you may need to install the 32-bit versions of some packages on your Linux system if it is a 64-bit system.
From: [email protected] <[email protected]> on behalf of Häbel, Catharina <[email protected]>
Sent: Monday, May 28, 2018 10:03 AM
To: [email protected]
Subject: ADPvcam: can't create IOC because of missing build (bin) folder
I have used the areaDetector R3-2 and the ADPvCam R2-2, EPICS 3.14.12.4 and Debian 9 to build an IOC for the Princeton SOPHIA-XO Camera. But there is no bin folder created as it is the case for e.g. by building an IOC for ADAndor. Any help is welcome.
Thanks
Catharina
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (kommissarisch), Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
https://www.helmholtz-berlin.de
AW: ADPvcam: can't create IOC because of missing build (bin) folder Häbel, Catharina
Re: ADPvcam: can't create IOC because of missing build (bin) folder Mark Rivers
Prev: Re: ADPvcam: can't create IOC because of missing build (bin) folder Mark Rivers
Next: Re: Open .opi file from command line with CSS Display Builder? Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Next: AW: ADPvcam: can't create IOC because of missing build (bin) folder Häbel, Catharina
ANJ, 06 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
