Hi:
The file path must be a workspace path, i.e. something valid within the Eclipse/CSS workspace.
Start CSS.
Invoke the menu CS-Studio, Utilities, Install Samples, select both the BOY and Display Builder examples
Now this will open the start of the BOY examples in the previously started CSS instance:
./css --launcher.openFile '/BOY Examples/main.opi'
.. and this will open the start of the display builder examples:
./css --launcher.openFile '/Display Builder/01_main.bob'^C
The single quotes are required because of the space in the file names.
Note that in practice I've found this to be fragile. The open-from-command-line mechanism is technically based on a SWT locating the already running instance by looking for its main window.
In our control room, the command-line mechanism fails to find an already running instance of CS-Studio that has been running for a while.
I believe that's related to us having several operator interface computers all use the same generic "operator" login with the same NFS-mounted home directory, and X11/GTK storing some information in the $HOME directory.
So going forward, for the 'phoebus' update project that aims to remove Eclipse from CS-Studio, we simply listen on a TCP port for files to open, which so far seems easier, faster, more reliable, and can also used by e.g. 'telnet' or 'nc' to open files.
-Kay
From: [email protected] <[email protected]> on behalf of J. Lewis Muir <[email protected]>
Sent: Friday, May 25, 2018 6:25 PM
To: EPICS Tech-Talk
Subject: Open .opi file from command line with CSS Display Builder?
Hello.
How do I open a .opi file from the command line with Display Builder?
The OS is macOS High Sierra 10.13.4.
I have a "Basic EPICS" nightly build from:
https://ics-web.sns.ornl.gov/css/nightly
and I invoke it from the command line with a script named css.
I read:
http://cs-studio.sourceforge.net/docbook/ch29.html
and:
https://epics.anl.gov/tech-talk/2013/msg01791.php
and concluded I should run the following command:
$ css --launcher.openFile ./simDetector.opi
Unfortunately, that results in a segmentation fault. I assume this is a
bug?
I then tried specifying an absolute path to the .opi file:
$ css --launcher.openFile /tmp/simDetector.opi
That succeeded in launching CS-Studio, but I don't see the
simDetector.opi screen anywhere.
What am I doing wrong?
Thanks!
Lewis
- Re: Open .opi file from command line with CSS Display Builder? J. Lewis Muir
- Open .opi file from command line with CSS Display Builder? J. Lewis Muir
Re: ADPvcam: can't create IOC because of missing build (bin) folder Mark Rivers
RE: Open .opi filenames with spaces from command line? Mark Rivers
<2018>
2025
2026
<2018>
2025
2026
