1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tvx for pilatus randomic crash over ssh
To: Gabriel de Souza Fedel <[email protected]>
Date: Tue, 29 May 2018 10:27:28 -0500
On 05/28, Gabriel de Souza Fedel wrote:
> Hello,
> Did you have crash with tvx when accessing over ssh (-X) ?
> We change our client to Debian 9 (with mate), and now sporadically
> tvx closes (camserv keep running normally).
> I try to find some error message on server (where tvx are installed)
> and client, but I didn't find anything.
> Our tvx version is tvx-7.2.70.
Hello, Gabriel.
It would probably be best to ask DECTRIS since they wrote and support
tvx.
But if you're trying to fix the problem without them, you could, instead
of the "-X" option, try the "-Y" option to ssh which enables trusted X11
forwarding.
Or you could try to get a stack trace when tvx crashes.  You'd need to
figure out how to start it inside gdb, or attach to the tvx process with
gdb after it's started, or get a core dump file and analyze that with
gdb after the crash.
Lewis
Re: tvx for pilatus randomic crash over ssh Gabriel de Souza Fedel
Prev: RE: Open .opi filenames with spaces from command line? Mark Rivers
Next: Re: Open .opi filenames with spaces from command line? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: tvx for pilatus randomic crash over ssh Gabriel de Souza Fedel
Next: Re: tvx for pilatus randomic crash over ssh Gabriel de Souza Fedel
ANJ, 29 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
