1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Open .opi filenames with spaces from command line?
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 29 May 2018 10:46:41 -0500
On 05/29, Mark Rivers wrote:
> I then open CSS with no command line arguments and then use File/Open
> in CSS to open the top-level display, for example ADTop.opi.  From
> there I can open simDetector.opi and all related displays, and CSS
> will find them with no problem because they are all in the same
> directory as ADTop.opi.
Hi, Mark!
Thanks for sharing your method.  I'll try that.  I assume you also set
the P and R macros in CSS under Preferences -> CSS Applications ->
Display -> BOY -> OPI Runtime?  (Or one of the methods noted in [1]?)
I was thinking that CSS would be the fastest works-out-of-the-box
solution for areaDetector and plugin displays under Windows, but now
I'm not so sure.  I was trying to avoid compiling medm for Windows and
installing an X11 server on Windows.  But maybe I'm close with CSS, and
if I can accept the inconvenience of not being able to start a display
from the command line, it will still be fine.
Thanks!
Lewis
[1] https://epics.anl.gov/tech-talk/2012/msg00375.php
RE: Open .opi filenames with spaces from command line? Mark Rivers
Open .opi filenames with spaces from command line? J. Lewis Muir
Prev: Re: tvx for pilatus randomic crash over ssh J. Lewis Muir
Next: Re: tvx for pilatus randomic crash over ssh Gabriel de Souza Fedel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Open .opi filenames with spaces from command line? Mark Rivers
Next: RE: Open .opi filenames with spaces from command line? Mark Rivers
ANJ, 29 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
